Old 06-04-2008, 09:35 PM   #176
Coda O'Dell
Coda O'Dell's Avatar
Re: project INCREDIBLE HULK 6.2L with 6L80E
Love the truck. Where in tulsa are you. I live in Sapulpa
Coda O'Dell is offline   Reply With Quote
Old 06-04-2008, 09:59 PM   #177
68 short step
im in BA......
68 short step is offline   Reply With Quote
Old 06-07-2008, 04:14 PM   #178
C-BOMB
are you going to use the fly by wire? we just wired up a 07 5.3 for a rail buggy and got the harness for the pedal from speartech. worked out perfect
C-BOMB is offline   Reply With Quote
Old 06-07-2008, 04:40 PM   #179
68 short step
yelp, keepin the DBW
Old 06-08-2008, 06:13 PM   #180
tk-mpl
tk-mpl's Avatar
Hey 68SS, What intake kit are you using with these gen4 engines and are you using the original MAF sensor to the engine???
Thanx.
Trevor
tk-mpl is offline   Reply With Quote
Old 06-08-2008, 08:44 PM   #181
68 short step
i like to use the intake and air filter for a 00-02 denali/tahoe (aftermarket one)... and yes i keep the stock MAF and front O2s.... im not a huge speed density fan, especially for these GEN 3/4 engines
Old 06-08-2008, 09:50 PM   #182
tk-mpl
tk-mpl's Avatar
Do you have a pic of the 6.2L intake setup yet?? Is there any mods to make the intakes fit?
Thanx.
Old 06-09-2008, 12:35 AM   #183
Ackattack
Ackattack's Avatar
how does it work with the ride height sensors? Does it try to adjust for body roll while going around a corner?
Found where to get my cruise control switch/turn signal!
Ackattack is offline   Reply With Quote
Old 06-12-2008, 08:43 PM   #184
68 short step
Thanx.
none yet, no mods other then makeing a mounting bracket to support the weight of the tube/air filter....
yes, it sences the height of the suspension at any given time or load and adjusts it to your pre-sets....
some progress,
got the tranny lines mocked-up, on the 6l80e they come out of the driver side (unlike the 4l60e)...they are routed tightly under the tranny and then terminate into a AN tube adaptor....from there its just a few 90* and streight fittings, with bradided -6 line........
also doing the wiring, GM keeps switching PCM pins on me, so for all doing a swap 05-06 E38 computers are adiffrent from 07-08 38 computers... (computers are the same, just the pins that connect the wires to the PCM are diffrent) so i got some 07 E38 PCM pins comming...
here is the orginized mess
and a sneek peak at this
Old 06-12-2008, 08:56 PM   #185
GRIMSS
GRIMSS's Avatar
That dash out of a vett?
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 06-12-2008, 09:00 PM   #186
68 short step
you are wise, grasshopper........
Old 06-12-2008, 09:03 PM   #187
GRIMSS
GRIMSS's Avatar
Sweeet!!!!
2001 GMC SIERRA
1968 Camaro
Jared
Old 06-12-2008, 09:04 PM   #188
GRIMSS
GRIMSS's Avatar
anything mocked up yet? Pics
2001 GMC SIERRA
1968 Camaro
Jared
Old 06-13-2008, 09:13 AM   #189
my67chevytruck
Under Construction
my67chevytruck's Avatar
Looking good don.. Keep at it...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-13-2008, 07:51 PM   #190
pcorriveau951
pcorriveau951's Avatar
68 short step what are the wire in this picture covered in? they look clean wrapped in this braiding, are the rest of the wires in your truck going to be covered in the material? Keep up the great work.
pcorriveau951 is offline   Reply With Quote
Old 06-13-2008, 11:30 PM   #191
tk-mpl
tk-mpl's Avatar
Are you using the 2000 f-body pacesetter headers on this one too. Where do you get them. I also tried a previously posted link for the intake that you used aswell and it didn't work so if you can share that aswell that would be great.
Looking good..
Watching and learning...
Old 06-14-2008, 01:02 AM   #192
turbohacker
PISS POOR
turbohacker's Avatar
Is that one of those new trick composite plastic drive shafts?!
Great build, im really exicted to see what you do with that vette dash...
Slammed 67 long bed with vette suspention build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=291149
turbohacker is offline   Reply With Quote
Old 06-14-2008, 11:04 AM   #193
68 short step
that is how it came from airide, but it is basically the same thing as the painless "powerbraid" wire sleeve
PN 70901 1/4" dia. x 20ft
70902 1/2"dia. x 10ft
70903 3/4" dia. x 6ft
70904 s" dia. x 4ft
Looking good..
yes they are for 00-02 camaro firebird (race style, with no emission stuff)
im lookn for the link on the intake, i got it from ebay, for the 00 yukon
yes its good up to 1HP
Old 06-16-2008, 11:15 PM   #194
68 short step
with this tranny being so much bigger, and the mount being 2.5" higher up then the 4l60e.... i was afraid it would interfer with the trans tunnel, so after a few measurements, i desided it would interfer....so i put the cab back on the frame (with the help of the wife) to see where and how bad it was interfering......after we got it on i had her look to see where it was touching and i marked it from inside.....so i cut the hump out, and set the cab completly down.....and with the engine moved back as it is on this truck, it sits close to the firewall, but fits the contores of the firewall like a glove......it looks awsome sitting up on the firewall, they couldn't of done a better design back in 71 to make a new engine fit so good.....
here are some pics
Old 06-17-2008, 10:45 PM   #195
71Hulk
Tell mo hulk says 2 smile...you need to taker to geter nails done!
so what r the plans for that big hole in the floor board?
71Hulk is offline   Reply With Quote
Old 06-18-2008, 10:58 AM   #196
68 short step
make a new tunnel... what you didnt see the flower on the toe nails???
Old 06-18-2008, 11:58 AM   #197
SCOTI
SCOTI's Avatar
Originally Posted by 68 short step View Post
....what you didnt see the flower on the toe nails???
She gets my vote for 'hottest chick in this thread'.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-18-2008, 12:13 PM   #198
Hart_Rod
Hart_Rod's Avatar
Why didn't you use the "LH8" oil pan? I think you mentioned it before. Do you have the dimensions? I was looking at this one on ebay, but not sure if it will work.
http://cgi.ebay.com/ebaymotors/ws/eB...238436426&rd=1
R/
Hart_Rod is offline   Reply With Quote
Old 06-18-2008, 12:19 PM   #199
gringoloco
A guy with a truck
gringoloco's Avatar
Will a stock "high hump" fit?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-18-2008, 01:34 PM   #200
68 short step
R/
yes the LH8 pan will clear, but the camaro pan is still shallower......and we're gonna be low, so ground clearance is a concern.....
here are the demensions
most defently.....the interferance was mainly on the back part (tailshaft houseing) but instead of modding that one spot and looking like poop, i desided to raise the entire thing...
