02-03-2003, 05:08 PM | #1 |
swapping cabs from a 72 to 67...
Is there much to this?? I am looking at swapping a 72 Chevy cab for a 67 GMC cab. I know that the wiring harness should be changed over, but is there much difference in these cabs? Will the 70 Chevy doors I have fit on this 67 cab? Is there anything I should be forwarned about before I make an offer on this cab?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
02-03-2003, 05:19 PM | #2 |
Fabricate till you "puke"
The 67 had a hand E brake, but other than that & the wiring it should be a bolt on. Good luck....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-03-2003, 05:47 PM | #3 |
cool, I know where I can get a 67 cab that doesn't require a ton of work, for next to nothing
02-03-2003, 05:56 PM | #4 |
Resident Curmudgeon
Unless you are real clever you'll be forced to use the rod linkage accelerator instead og the cable one on your 72. If it's available with cab grab it.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
02-03-2003, 10:20 PM | #5 |
Can you just take pedal and cable for 72 and put on 67 cab??? Just asking because Im doing the same thing???
02-03-2003, 10:30 PM | #6 |
Resident Curmudgeon
No. The firewall is drilled differently for the brackets, plus the cable requires a square hole to mount the plastic clip through. Compare your current setup to the pre-71 cab fire-walls. You'd have to graft in the entire section from your existing cab or somehow duplicate it. It is not a bolt in swap.
02-03-2003, 11:21 PM | #7 |
I totally spaced that throttle rod issue! I did graft a pc of a 71 firewall to my 69 to convert to cable throttle. At the top, I just drilled a hole, & filed it out for the cable(that saved welding a big pc in the firewall)...crazyL
