Old 02-03-2003, 06:45 PM   #1
grandpastruck
tail and brake light problem
Help, I have turn signals and headlights, but no reverse, brake or taillights. Meter says I have no signal to the reverse or tail/brake lights at the back or leaving the cab, so presumably not a ground problem (?)
TAILLIGHTS: There’s no power from the light switch to the tail lights. Does that mean the switch is bad—or does power for the taillights depend on a different circuit than the headlights?
When I took the light switch apart everything looked fine—but if I short the light switch connector from the red wire (power for the headlights) to the brown wire (tail/brake light) my tail lights go on.
Where does power for the taillights come from? Is there something I’m missing here?
REVERSE LIGHTS: I haven’t really started to try to figure this out but I do know that little half-moon connector is just hanging loose by the steering column. It’s not clear to me from the shop manual how/whether this should be connected. Perhaps I’m missing the back-up switch entirely? Would this make any difference as far as my brake and tail lights?
Carlos
grandpastruck is offline   Reply With Quote
Old 02-03-2003, 10:15 PM   #2
Z-72
Do you have dash lights? If not check the fuse.
72-C-10-LWB-Big Block-TH400- PosiTrac Leaf Springs- A Dark Green Ford Eaten Machine. And those are not rust holes, there cooling vents..
Z-72 is offline   Reply With Quote
Old 02-03-2003, 10:38 PM   #3
jim71chevy
On my 71 chevy it was the turn signal switch in the coloum drove me nuts to find it, mine was doing the same think as yours.
jim71chevy is offline   Reply With Quote
Old 02-04-2003, 12:02 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
turn signal switch wouldn't cause the parking lights to not work.
Check your fuse, and if that is good, then you'll need to find the wire going from the fuse box to the light switch.
I believe the same fuse does the tail lights and stop lights, but I may be mistaken on that.
Old 02-10-2003, 04:23 PM   #5
grandpastruck
Smile
Thanks Longhorn, Z-72.
It was (more or less) the fuse.
For anyone who encounters similar problems, my fuse was good and my multi-meter showed voltage going to the light switch... but only when the switch was in the off position.
Turns out the fuse contacts were sufficiently corroded that when I put a load on the circuit by turning on the switch, the voltage dropped to zero. Very confusing--especially since once or twice everything briefly worked.
I cleaned up the fuse contacts and now everything works great.
Carlos
Old 02-11-2003, 12:41 AM   #6
Longhorn Man
Sweet.
A good way to clean the contacts is a solution of Arm&Hammer baking soda and water. Put it all in a spray bottle and hose it all down. (DISCONNECT YOUR BATTERY FIRST!) The solution eats the corrosion and leaves it pretty darn clean.
If your carpet is nice (unlike mine) I wouold recomend pulling it back first.
Of course, you probably coulda heard this yesterday huh?
Old 02-11-2003, 04:33 AM   #7
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
Make sure the rear harness is connected at the firewall, It is separate with tan, lt and dk green, brown and yellow wires.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
