06-09-2008, 07:41 PM | #1 | |||
Union Electrician
Pics of plug wire routing with hei and ram horns
I need some ideas on how to cleanly run my new custom fit plug wires and I still have my ramhorns and am using HEI any help will be greatly appreciatede
TIA....Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
06-09-2008, 07:48 PM | #2 |
Re: Pics of plug wire routing with hei and ram horns
We make wire separators out of electrical ties and use 180 degree ends on the spark plug wires to keep them away from the Rams horn manifolds. Here is a picture to show you the idea.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
06-09-2008, 07:54 PM | #3 |
Randy, Here's the way I routed mine with HEI and ramshorn exhaust. Pic shows point dist. instead of HEI, but it routes the same. Hope this helps? You can get the plugwire stands from GMCPauls. He has them in stock.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. Last edited by OhioDan; 06-09-2008 at 07:56 PM. |
07-02-2010, 10:04 AM | #4 |
bringing this one back from the dead... borrowed a pic from Bruce88... I already have 90 degree boots on my wires or i'd go this route... looks nice.
40200 - JEGS 8.0mm Red Hot Power Wires RNM-1101S - R&M billet wire looms
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 07-02-2010 at 10:06 AM. |
07-02-2010, 10:20 AM | #5 |
I used the plug wire off of a vette when i had rams horn manifolds. they are much longer than the truck wires which allows you to route the wires under the manifolds.
LMC has some spark plug wire stands/holders that will work for these types of plug wires and you can see how they are routed. on page 158, in the Ignition section, of my LMC catalog, they have the plug wire retainers for the vette style wires with the ram horns manifold. and depending what version of the manifolds you have, i would grind the manifold casting a bit around plug 6. this was notorious for burning the boots and casuing arching. the manifolds pictured above are much nicer castings than mine were and they clearly dont have the problem. but some do. Last edited by dznucks; 07-02-2010 at 10:24 AM. |
07-02-2010, 11:02 AM | #6 |
I just run them the length of the valve covers (top) and curl them around the front
07-02-2010, 11:23 AM | #7 |
OHIODAN has the right idea.... thatz how i did mine..
07-02-2010, 11:48 AM | #8 |
alright where are you guys getting these long ol wires from? custom making them? I ordered mine for a 77 chevy truck and they work and clear the ramhorn but they look awful, DZNUCKS: what year vette should I ask for?
1967custom |
07-02-2010, 02:39 PM | #9 |
Under Construction
most use universal, cut to length kits, vs pre-fabbed.......
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
07-02-2010, 02:58 PM | #10 |
Moderator
Mine are from a 77 Vette, they are long enough to route under the rams horns.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
07-02-2010, 03:39 PM | #11 | |
Under Construction
Have any pics, or did you route the same as the diagram above?
07-02-2010, 04:33 PM | #12 |
Moderator
Same as Ohiodans diagram.
07-02-2010, 07:56 PM | #13 |
This is what I did when I had ramhorns. I had them routed exactly like the diagram. Worked great.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel Charleston, South Carolina |
07-02-2010, 09:45 PM | #14 |
Here's how I did mine...mostly stock routing except I did not run the front wires behind the manifolds as I couldn't find a good place to the hold them secure and was worried about burning them.....so I used a clip on the frame..
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
07-02-2010, 11:01 PM | #15 |
Been awhile since I saw this thread. I used plug wires for a 75 vette with HEI. Worked good.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. Last edited by OhioDan; 07-03-2010 at 06:54 AM. |
07-02-2010, 11:10 PM | #16 |
I second the billet plug wire holders... I had those on mine and they are coming back unless I do a duramax / allison swap
07-07-2010, 10:27 AM | #17 |
on the front plug wires, i routed mine between the engine and the motor mount...
10-01-2010, 11:55 PM | #18 |
Wow, what did you paint the exhaust manifolds with? POR15? Looks great!
Beauty is in the eye of the beer-holder. Praise the lowered! |
12-24-2010, 10:47 PM | #19 |
But Found Her 25yrs Later!
I like it.
12-25-2010, 01:57 AM | #20 | |
http://www.eastwood.com/factory-gray...ating-kit.html RM
12-25-2010, 11:21 AM | #21 |
Sierra Grande Club
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
12-25-2010, 03:12 PM | #22 |
ok so the 77 or 75 vette are longer?
1971 K5 CST Blazer 1951 -3100 5 window short bed 4sp 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
12-25-2010, 03:56 PM | #23 | |
My wires are run per the diagram. I used what NAPA had labeled as for an RV of that same vintage. probably the same as the vette. Plenty of length to route in various different pathways.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
03-02-2013, 12:44 AM | #24 |
love this thread. going to start my wires over this weekend!
03-02-2013, 02:22 AM | #25 |
I know I said I ran my wires as per diagram but that was before I rebuilt my engine. After the rebuild I used the billet aluminum wire managers and went over the top of the ram horns. I used the Kevlar wire shields to protect the wires from the high heat stored in the manifold. The wire managers keep the wires far enough away from the manifold that I have not had any trouble.
