Old 06-09-2008, 10:12 PM   #1
Rickey
Rickey's Avatar
fan motor won't run on high
The heater / ac fan won't run on high speed all other speeds seem ok. Does anyone have any ideals.
Rickey is offline   Reply With Quote
Old 06-09-2008, 10:30 PM   #2
hootz
hootz's Avatar
Re: fan motor won't run on high
if your truck is a/c equipped it will use a high speed relay. There will be a fused wire to the relay that is the feed for high speed. this fuse will be inline and usually within 12-18 inches from the relay. if the fuse is good and the connection at the relay is good make sure you are getting power at the relay from the switch in high speed with the key on and selector on heat or a/c. if you have power at the battery feed terminal and the ignition feed from the switch in high suspect the relay itself.
Never say Never!!
hootz is offline   Reply With Quote
Old 06-09-2008, 11:26 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
When my high speed quit, it turned out to be a bad switch. My local NAPA had one.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 06-10-2008, 12:10 AM   #4
Mint68
Mint68's Avatar
Mine has been acting funny. When I would switch it to high it would blow lower than the medium speed; but when I would push it up just a little it would kick back to high. I pushed the connector and wiggled it then it sliped on more. Fixed the problem; hopefully this is your problem, it is dirt cheap to fix.
Mint68 is offline   Reply With Quote
Old 06-10-2008, 12:32 AM   #5
wzuke
wzuke's Avatar
Mine had the same symtom - new blower switch fixed it.
wzuke is offline   Reply With Quote
Old 06-10-2008, 07:39 AM   #6
Hutch
Hutch's Avatar
Rickey,
Check the ground wire from the relay on the firewall.
It is very short
It is located up high between the glove box and passenger side wall.
There is a short ground wire that is supposed to go one of the shroud bolts that come through the fire wall
Easy test is to attach a short piece of wire while it is on high from the relay to ground.
A lot of folks do not get the ground re-attached correctly while working on the heater coil.
The symptoms are
Low= Low
Medium= Medium
High = Very Slow
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
