Old 06-10-2008, 11:13 PM   #1
Slammed70
Slammed70's Avatar
PCV vs. Breather.....
Well I found where that burning oil smell was coming from, one of my breathers is leaking from under where the vents are. And my "old know-it-all" neighor told me I should ditch one of my breathers(I have one on each valve cover)and sustitute a PCV instead.
Just wondering what that would do for me?
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 06-10-2008, 11:21 PM   #2
clay68c10
clay68c10's Avatar
Re: PCV vs. Breather.....
It lets the engine suck in that excess crankcase pressure so it doesn't build up and cause your current leak.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-10-2008, 11:27 PM   #3
Slammed70
Slammed70's Avatar
Oh, so they are a good thing then....
Aight, Ill pick on up tomorrow.
Old 06-11-2008, 12:37 AM   #4
1970 chev truck
Weldin' it up
1970 chev truck's Avatar
i dunno i have two breathers on one side and i have no leaks at all
-Paul-
RIP El Jay
Dirt is for Racing, Asphalt is for Getting There
If need be, send me an e-mail at cbm_racing_90@hotmail.com
1970 Custom/10 LWB 4X4 350/TH350
2003 Silverado 1500 Ext. cab
1974 Kawasaki 175 F7 Enduro
2002 Polaris Edge X 700
1970 chev truck is offline   Reply With Quote
Old 06-11-2008, 01:00 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there is absolutly no good reason to NOT have a PCV system. Yes, it is a smog control item, but it costs no power, and is a great benifit to your engine.
Old 06-11-2008, 01:12 AM   #6
Sinisterspeed
Sinisterspeed's Avatar
yeah, What he said. I have one on my engine. It doesnt need it to operate so when the neighbor kid was installing his engine that seemed to have excessive blow by or high block pressure in his ..... FORD... I robbed my brand new grommet,PCV and hose. Put it on his valve cover and poof no more blowing the dipstick out of his engine. Needless to say he has yet to replace the parts but Mine ran fine without issue for its long trip outside the other day. I will still replace it and always have one on my engine as well.
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 06-11-2008, 01:42 AM   #7
Slammed70
Slammed70's Avatar
I was gonna get one, but it slipped muy mind when I was handing the parts store guy all my money. And the closest parts store is ~30 miles away so it wasnt in my plan to turn around and buy a $4 item if I didnt need one, since I have a bucket full of breathers Ive pulled of my other engines. So I just threw them on as a temporary fix so I can get it going, and forgot all about it until now.
Old 06-11-2008, 01:44 AM   #8
dwcsr
Hollister Road Co.
dwcsr's Avatar
The PVC does serve a purpose. It draws out the gas fumes from the crank case when you flood or the rings don't seal like they used to and the gas passes the rings. One good back fire with fumes in the pan and it will come off promptly, I'm sure you've heard of grenading the pan.
The other purpose is to help seal the rings when running. Vacuum in the crank case is a good thing it actually add HP.
Old 06-11-2008, 06:20 AM   #9
Longhorn Man
plus the natural bybrouct of combustion hangs out in there as a very corosive gas and becomes acidic. It then contaminates the oil and atacks the metals inside the engine.
Old 06-11-2008, 10:26 AM   #10
68_chop_top
68_chop_top's Avatar
The breather allows air into the valve train and crankcase. The PCV draws air OUT from the block and is routed to under the carb where the gases are burned in combustion. You need both.
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 06-11-2008, 03:21 PM   #11
jonnybravo
jonnybravo's Avatar
i have pretty severe blowby is it ok to put another pcv valve on the other too and then tee the two together
jonnybravo is offline   Reply With Quote
Old 06-11-2008, 03:24 PM   #12
68_chop_top
The more the better! Better to burn the gases rather than blow off to the environment.
Old 06-11-2008, 03:43 PM   #13
cparman
sharp as a marble
I have a PCV in the right valve cover, and I plumbed a tube from inside of the air cleaner to a grommet in the left valve cover. This way you have clean ( well cleaner ) air going into your motor. My buds think I think too hard, but the air going into the engine is filtered. If someone on the board will talk to me like I am stupid, and explain the picture thing I will post a pic of this, and my truck
cparman is offline   Reply With Quote
Old 06-11-2008, 04:30 PM   #14
Longhorn Man
I guess I should have clerified and described/explained the whole system again when I said it is benificial to install. The needing both was implied. A PCV with no breather/air filter tube will do nothing except probably suck the intake and/or valve cover gaskets into the engine.
cparman, let your buddies raz you all they want. You have the correct set up.
jonnybravo, the only way you can do this and have it work properly, would be 2 PCV valves on one valve cover, and breather/tube to air cleaner on the other. If you just go valve on one side, and valve on the other side with no way to get air in, you will suck the gaskets into the engine.
Old 06-12-2008, 12:35 PM   #15
leddzepp
Moderator
leddzepp's Avatar
If for no other reason, you should run PCV to keep oil from blowing all over your engine compartment. It keeps it a whole lot cleaner.
Old 06-12-2008, 12:48 PM   #16
mvfd70
mvfd70's Avatar
What about those of us running a 6 cyl. What would be a correct set up for engines with only one valve cover?
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 06-12-2008, 01:12 PM   #17
72-c20
Packrat
72-c20's Avatar
yeah..... I swapped carbs 2 days ago and left the PCV valve not connected to a vac source.... bad juju. the breather tube was puking oil all over!!!
redid the connections with all hooked up and it's much happier (and cleaner)
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 06-12-2008, 02:11 PM   #18
Longhorn Man
The same way they did stock. A PCV in one hole, and a breather/clean air tube from the air filter.
You can't see it too well in this photo, but you can see the breather tube on the drivers side of the valve cover going to the air cleaner. I'll assume the PCV is under the air foter towards the rear.
Old 12-17-2012, 05:34 PM   #19
heathbirkendahl
How do you tell when the PCV is bad? And it move around and still be bad? Mine moved but did not rattle. Made more a thunking noise.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 12-17-2012, 07:14 PM   #20
truckster
truckster's Avatar
The PCV valve should rattle when you shake it. You can usually clean them out with a little brake parts cleaner if they're not too dirty, but they're also really cheap, so it makes sense to replace it.
truckster is offline   Reply With Quote
Old 12-17-2012, 08:08 PM   #21
heathbirkendahl
Ok. Mine did NOT even come close to rattling. It was clunky and has an oily film in it.
Old 12-17-2012, 08:36 PM   #22
fastcam1
Young gun
fastcam1's Avatar
what about the old small blocks 67 and earlier like the 327, you had the oil fill tube in front with a breather on it where was the PCV?
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 12-17-2012, 10:05 PM   #23
jaros44sr
jaros44sr's Avatar
They had a road draft system which was evacuated to atmosphere. Basically, the external tube was cut at an angle, as you drove the air rushing past caused a vacuum pulling gases out of the crankcase. There was a baffle in the lifter valley
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-18-2012, 01:19 AM   #24
fastcam1
Young gun
fastcam1's Avatar
So I have a set of Chevy script valve covers, what do I have to do so I don't have to drill holes in them?
Northwest C10's
Cameron sparks
Old 12-18-2012, 02:35 AM   #25
bk2life
Originally Posted by Slammed70 View Post
And my "old know-it-all" neighor told me....
so i guess your old know it all neighbor is a bit wiser than you think....
bk2life is offline   Reply With Quote
