Commander Taco Bello
What would you do with $10k and a $500 roller?
If someone gave you a $500 farm truck with the usual dings and dents and non running I-6 with $10k in the glove box and told you to build a truck that goes fast in a straight line; what would you do and how?
Assume a 60-66 truck with a solid 1/2T frame, trailing arm setup and 6 lug wheels with drums all around. The only additional criteria is that it needs to be able to make the drive to the track and back under it's own power. |
Prestige member Old Farts Club
Re: What would you do with $10k and a $500 roller?
mild 502 motor for drive-ability, custom rad, built 700r4 by local "Custom Trans" box the trailing arms, air bag the rear springs, use later model front disc and 14 bolt rear to try to stay in budget -10K isn't allot for racing. Alternate would be just buying a wrecked truck with a 5.3 or 6.0 install the drivetrain in your truck and have fun
Hey sombodys gotta do it! ![]() |
454 SBC, Tremec TKO and a Qjet (ok, just HAD to throw that part in there)
that's basically what i had, except the $10k wasn't in the glovebox, haha. 406 small block, 4 speed, 12 bolt truck rear. runs low 12's all day, has been high 11's on occasion
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
