Old 06-14-2008, 09:49 PM   #1
Curly86
You want it there when???
Curly86's Avatar
Delay wiper module
where is the module for the delay wipers mounted on the 86 silverado and what does it look like? tks
1986 Silverado Flatbed 400 SB with 350 turbo
1997 Ford Explorer with 302 mydrive to work ride
1978 Gmc Midas RV 21ft with 46,000 actual miles
2003 Chevy Avalanche 5.3 327 and Tweety Bird Yellow
Big Sandy Survivor 09
Trucks in the Blue Grass Survivor 09
TNCTC
Streetcruzin
Curly86 is offline   Reply With Quote
Old 06-14-2008, 10:22 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Delay wiper module
It's black with an aluminum heat-sink and is mounted cross-wise to the underside of the of the steering column right behind the lower dash cover panel. To remove it simply grasp it and slide it straight up the column then disconnect the wiring harness's at either end of it.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 06-14-2008, 10:27 PM   #3
Curly86
Curly86's Avatar
Ok tks will check it out
TNCTC
Streetcruzin
Old 06-16-2008, 04:50 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
It looks like this:
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-17-2008, 05:32 AM   #5
87Bob
Can a non-delay be made a delay wiper by replacing the switch and adding the heat sink?
87Bob is offline   Reply With Quote
Old 06-17-2008, 06:12 AM   #6
S10Fan
Old Heap Driver
I did. Picked up a column from a 1984 Blazer along with the module and added both to my 1980 C-10. I had to sort out the wiring, for mine the wire colors matched. Eliminated to dash switch and use the column mounted switch from the Blazer column. Works great.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 06-17-2008, 06:15 AM   #7
James McClure
One shot, one kill.
Bob, the answer is yes, thats how GM did it. Wiper motor is the same. You'll have to change the signal light lever also. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 06-18-2008, 02:36 PM   #8
seanconnery
Does anyone know what the module costs and if i can get it at a major store? The Autozone bufoon on the phone had no idea what it was...
G to the M to the C......fool!
RIP Jerry Reed "The Snowman"
seanconnery is offline   Reply With Quote
Old 06-20-2008, 11:22 AM   #9
seanconnery
Anybody?
Old 06-20-2008, 11:26 AM   #10
rcbildr
rcbildr's Avatar
I looked in to that at a local parts store and they couldn't find a listing. I think it will have to be bought from a dealer. I ended up finding one at a local pull-a-part and got lucky...it worked.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 06-20-2008, 12:51 PM   #11
BLE 'BURBAN
Yep it's a dealer item only.
Old 06-20-2008, 02:20 PM   #12
87Bob
Kinda makes me wonder what other vehicles had this style of delay on them it might open up the possibilities of finding one in a junk yard in another restoration catalog (ie: Classic Industries Camaro). Does anyone have a picture of one installed on a column? I have recently bought a tilt column and it has the delay turn signal lever but I see no delay module on it.
Old 06-20-2008, 02:59 PM   #13
seanconnery
I'm even kind of wondering if one can simply not use the delay module and just plug the 2 harnesses into one another. Can you do this? I don't really need delay wipers anyway; I just want wipers that work! Can you use the wipers without the delay and just replace the module when you feel like, or is it best to replace it right from jumpstreet?
Old 06-20-2008, 03:51 PM   #14
BLE 'BURBAN
I'd imagine that any 80's -90's GM product with the same style column would have the same unit.
Old 06-20-2008, 04:00 PM   #15
BLE 'BURBAN
Sure you just won't have any delay is all.
