Old 02-04-2003, 04:48 PM   #1
chevy68388
king $h!t
chevy68388's Avatar
1 ton 4x4
ok i want to know how mucha 1 ton 4x4 weights compared to a 1/2ton 4x4 cause im going to make my truck a 1 ton and get farm tags and i dont know how much to put on the weight slip that i have to take up to the dmv
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s
chevy68388 is offline   Reply With Quote
Old 02-04-2003, 06:07 PM   #2
Yukon Jack
Yukon Jack's Avatar
I believe what the DMV is gonna be more interested in is what your truck can handle safely load wise rather than how much it actually weighs. I could be wrong.
Just putting 1 ton axles under it doesn't mean it can handle the same weight as a 1 ton factory truck. A 1 ton from the factory is going to have a 1 ton frame which is structurally stronger and the dimensions are different from a 1/2 ton or 3/4 ton frame. Additionally, the springs under a 1 ton are going to have better weight capacity than those under a 1/2 ton or 3/4 ton. If your truck is lifted using aftermarket lift springs, they won't have the capacity of a 1 ton and may even have less capacity than factory 1/2 ton springs.
Hope that helps with your question.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-04-2003, 06:14 PM   #3
chevy68388
king $h!t
chevy68388's Avatar
well i told them it started out as a 1/2 ton they said they dot care they just need the weight of the truck so they know how much to charge for the tags and i know its not really going to be a one ton but its the only way i can get out of e check and now one better not say run alcohal cause i ran a gallon of it and still didnt pass
Old 02-04-2003, 06:26 PM   #4
Yukon Jack
Yukon Jack's Avatar
If worst comes to worst, run down to an aluminum place that takes cans and stuff and I bet they will weight your truck for free.
If you know how much it weighed stock, I would add about 100 lbs for each 1 ton axle, and if your gonna be running 44's, about 120 or so additional weight for each tire - that should put you pretty close.
Old 02-04-2003, 06:41 PM   #5
chevy68388
king $h!t
chevy68388's Avatar
well i was going to run down to the feed mill we have in town and just put tractor weights in it till its was closei think its weights right now like 5000s so add 200 for axles and im going to end up running 38s so bouthmm 5600 sound bout right thats kinda weird cause my 1/2 ton ford weights 5400 pounds withe three people so prolly bout 4700lbs ok so does 5600 pounds soun good to u
Old 02-05-2003, 01:58 PM   #6
Yukon Jack
Yukon Jack's Avatar
My 69 weighed a little over 5600 with the 307.
Old 02-05-2003, 10:12 PM   #7
chevy68388
king $h!t
chevy68388's Avatar
well here i will tell u what it has u tell me what u think ok its a 84 short bed gmc 406 small with 4x4 14 bolt ff with a dana 44 front im trying my hardest to find a 60 its got a700r4 witha n208 its got ac tilt cruise bench seat hmm i think thats good enough so how much u think it woud weight
Old 02-06-2003, 11:33 AM   #8
Yukon Jack
Yukon Jack's Avatar
I bet your looking at about 5600 or so.
Old 02-06-2003, 03:53 PM   #9
chevy68388
king $h!t
chevy68388's Avatar
ok thanks
