06-19-2008, 10:35 PM | #1 |
help bad wheel hop
lets see i got a 70 gmc mild small block and cant get the power down but heres the real problem tight buget so low buck tricks is what im about right now any ideas thanks joe
06-20-2008, 08:31 AM | #2 |
Re: help bad wheel hop
Simple "slapper" type traction bars. Cheap and somewhat effective. They are not the greatest thing, but they do work. The dis-advantage is that they will not work with lowering blocks, but if you have lowering blocks, they are probably causing the problem anyway.
06-20-2008, 08:57 AM | #3 |
Leaf or coil suspension? It makes a difference on parts/mods recommendations.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-20-2008 at 05:34 PM. |
06-20-2008, 10:15 AM | #4 | |
The other (more expensive) option would be to convert to the trailing arm rear suspension of the Chevy's. If you could find a 67-72 Chevy truck with the coil spring setup to use in a junk yard on the cheap it would probably be your best bet for a reasonable cost. Add $300 for springs and shocks to the cost of the junk yard parts and a few careful cuts, measurements and welds later and you have a great setup for traction and handling.
~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 1970 Custom/10 LWB-Stock and ugly, for now. 2005 Custom Chopper-100ci Rigid. 2004 Dodge Ram...did he say "Dodge"... |
06-20-2008, 04:48 PM | #5 |
I just assumed leaf.....wheel hop with coils and 4 foot long truck arm doesn't seem to likely.
Besides, isn't the standard for GMC leaf, w/coils as option, just the opposite of Chevys. |
