06-21-2008, 02:51 PM | #51 |
sharp as a marble
Re: Brake Lines
Ok here goes. There might be pics, and there might not
I painted my master cylinder with the paint in the picture. I put 2 coats on it, letting it dry for 24 hours in between. Used a fom brush. Did this on my last car and it looked great 3 yrs later |
06-21-2008, 03:58 PM | #52 |
Grand PooBaa Member
Re: Brake Lines
I have see those mounts. CPP has left, right, and under the MC mounts. which ever way you can get it to work. Now I need brackets for the booster.
06-21-2008, 06:47 PM | #53 | |
Grand PooBaa Member
Re: Brake Lines
06-22-2008, 12:23 PM | #54 |
Grand PooBaa Member
Re: Brake Lines
After removing the headers and driverside shock this is what I have. Now where is the shipping bend?
06-22-2008, 12:24 PM | #55 |
Grand PooBaa Member
Re: Brake Lines
And the rest of the bad pictures.
06-22-2008, 12:25 PM | #56 |
Grand PooBaa Member
Re: Brake Lines
Last one.
06-22-2008, 01:36 PM | #57 |
sharp as a marble
Re: Brake Lines
vdog, I am going to put my truck up in the air, and shoot a couple of pics of my brake lines. I think from what I see, one of the new lines is pointing towards the radiator. That one is for the rear brakes. the other is for the front.
NOW, shoot a couple of pics of the new master cylinder, and the new prop valve. I will rack my truck in a few minutes, and get back to you this afternoon. Last edited by cparman; 06-22-2008 at 01:36 PM. |
06-22-2008, 02:39 PM | #58 |
Re: Brake Lines
The lines you have are for power brakes like mine. Here's my setup. I had to reposition the prop valve because I didn't use their prop valve.
The only shipping bend is the line for the rear brakes that run along the frame to the back by the gas tank and connect to the brake hose.
1997 GMC Sierra Ext 1965 Mustang |
06-22-2008, 03:19 PM | #59 | |
Grand PooBaa Member
Re: Brake Lines
07-05-2008, 08:58 PM | #60 |
Grand PooBaa Member
Re: Brake Lines
Ok did the Finelines thing, talk to bill again. From the first picture you see the square bend was not next to the frame, and I did not have a shipping bend.
So I bent the square toward the frame and that solved my problem. |
07-05-2008, 09:03 PM | #61 |
Grand PooBaa Member
Re: Brake Lines
So now assembly will start tomorrow, here are the painted parts. Forgot to include the painted headers.
