06-23-2008, 10:36 AM | #1 |
New 6 lug rear end in my 56 GMC
Well after 52 years the rear end in Frances is going further south and it’s time to change it out.
I don’t have a cutting torch or welder or that much money for that matter so I am going to try and keep it simple. My old girl is a work truck not a show truck so I need to get her back on the road as soon as possible. I spent Saturday searching salvage yards in the Jacksonville FL area. The only one I found that I think will work is this 12 bolt out of a 1983 4 wheel drive GMC. One drum and all of the brake parts are missing off one side but I would replace those anyway. I sand blasted and primed it to make it easier to work on. My original springs are 2 inches wide and 39 ½ inches apart. So that is 41 ½ inches from center to center. The spring pads on the new rear end are 40 inches apart and the pads are 2 ½ inches wide. That’s 42 ½ I am thinking I might be able to modify the pads with a plate welded on top.. Thinking…? I turned the U joint with one axel locked and it went just over 1 and a half times so the gear ratio must be around 3:07 3:08 That will be better than the original because I travel down Rt 95 everyday to work. http://www.neflnewhomes.com/56gmc/mvc-020f.jpg http://www.neflnewhomes.com/56gmc/mvc-021f.jpg http://www.neflnewhomes.com/56gmc/mvc-022f.jpg Anyone know how to read these codes on the shaft? looks like KAJ W064 1 E Any thoughts or comments? Cadman
56 GMC 1922 Dodge Rat Roadster 89 Gray Allante 90 Red Allante Turkey Run Photographer http://www.turkeyrun.com/photo_gallery.html |
06-23-2008, 01:21 PM | #2 |
Re: New 6 lug rear end in my 56 GMC
I would elongate the existing holes(1/2 in. each side) in the pads so it would be on center. Then look at the conversion kits sold by Brothers , CPP . All you really need are U-Bolts and Top Plates. But then shock mounts would become another issue.
06-23-2008, 05:04 PM | #3 |
I would cut the perches off and weld new ones on. They're cheap and it sounds like you anticipate doing welding anyhow. If you don't, your U-bolt plates likely won't fit because that one U-bolt will be spaced away from the spring ....
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
06-25-2008, 09:33 AM | #4 | |
Looks like you are correct the inside bolts will be fine and if I drill 2 holes in the old pads and a new centering hole 1/2 " inward on both sides it will bolt right up fine. I will keep posting pictures of my "Bolt in a late model rear end." Cadman
56 GMC 1922 Dodge Rat Roadster 89 Gray Allante 90 Red Allante Turkey Run Photographer http://www.turkeyrun.com/photo_gallery.html Last edited by cadman89; 07-03-2008 at 08:38 AM. Reason: added more pictures |
