Old 06-26-2008, 11:14 PM   #1
Nelson
Fan Clutch
I'm looking at replacing my fan clutch. Would anybody know the Napa part number for our trucks. There's about 5 different fan clutch part numbers, and just need a regular stocker. I'm planning a little road trip the US this weekend.
thanks.
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
Old 06-27-2008, 09:48 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Fan Clutch
Heres a bump for you....
I bought one many years ago. The parts counter guy said it would work on any year, stock 350 engine. I'd tell them if you have a/c, ps, pb, and that it's a stock 350. Seems to me they should be able to help you out.
But if they can't maybe someone here can give you some direction.
68gmsee is offline   Reply With Quote
Old 06-27-2008, 04:02 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fan Clutch
Lots of variables in a 38 year ols truck.
What side is the alt mounted?
Is the engine in the proper location?
Old 06-27-2008, 04:12 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Fan Clutch
I would think there was a number on the old one.If it worked until it went bad then that number should work.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-27-2008, 06:49 PM   #5
Nelson
Re: Fan Clutch
It's a stock 350, auto with 350th. The alternator is on the drivers side with the proper era alt bracket.
I guess my best bet is to take the old one with me to the parts guy at Napa.
thanks
Nelson
1970 C10 350 Auto.
A/C not Working
Old 06-27-2008, 08:51 PM   #6
cparman
sharp as a marble
Re: Fan Clutch
napa # 271305 this is a centrifugal type fan clutch. they make another type, and is a cheaper version. In the deep south, and at my shop it is the type above or no type. There are 2 different bolt patterns on the water pump hub, and I think this FC will accomodate both. Do not freek out when you drive away the first time. It will sound like a jet taking off.
cparman is offline   Reply With Quote
Old 06-27-2008, 10:58 PM   #7
Longhorn Man
Re: Fan Clutch
Why would you want a centrifugal one? The one with the little spring in the center is better. Even at speed, if it senses the air temp through the rad is too high, it'll kick on the fan and get more air in.
Old 06-28-2008, 07:49 AM   #8
Boog
laying low
Boog's Avatar
Re: Fan Clutch
Exactly. My experience with centrifugal fan clutches it seemed to work backwards to what was needed. It freewheeled at idle when you need engagement and locked up at cruise speed when it shouldn't need it. I went back to the stock thermostatic fan clutch and have always been please with them. Standard duty clutch is fine for stock setup. Go with heavy duty for towing and hauling needs.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-28-2008, 08:26 AM   #9
cparman
sharp as a marble
Re: Fan Clutch
my bad! the part # posted is for the one with the spring. If I read the description right last night, I thought it said centrifugal??? The one with the spring is the preferred type
Old 06-28-2008, 04:16 PM   #10
Longhorn Man
Re: Fan Clutch
Boog... thanks. Last night i could not for the live of me remember the word i was looking for.
thermostatic
cparman... glad that's what you ment. the other one is just crap in a box.
Old 07-07-2008, 09:44 PM   #11
Nelson
Re: Fan Clutch
Well I found what I was looking for. It was the clutch with the little spring in the middle. Since I had it out, it was good time the paint the fan and pulley.
It was also nice to see that the fan clutch was made ing the USA, and not China.
Nelson
1970 C10 350 Auto.
A/C not Working
Old 07-08-2008, 02:49 AM   #12
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Re: Fan Clutch
True.
You'll get a whole lot more fan roar with a new, healthy clutch. I used to have customers come back to the shop all the time after a clutch replacement thinking something was wrong. Their old, wimpy clutch wasn't driving the fan hard enough to make any noise and they'd gotten used to the sound (or lack thereof).
Lugnut64052 is offline   Reply With Quote
