#176 |
Re: Tri-Pro's "Project GPW"
Those look awesome, did you get the 7" round capsules from CCT or where? Also, do you have a picture of the lights on? I'd just love to see a 67-72 with HID's lol
#177 |
![]() Join Date: Apr 2005
Hey Jon, the trucks looking good. Quick question, are you missing a washer on the shock? Not sure if I'm seeing it correctly, but looks like there should be a big flat washer on the outside of your shock. Anyways, keep the pics coming.
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#178 |
Damn Yankee
#179 |
that's it...thanks, I wanted to compare that to mine... looks good too...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#180 | |
Damn Yankee
What should it look like? |
#181 |
Dipstix look good, how'd the oil one go in? Gotta get one...
How close is the cab to being dun?
#182 |
Damn Yankee
#183 | |
The cab that sits in the corner, all by its lonesome
#184 |
Damn Yankee
What I don't get about the kickdown cable being so long is that it's specifically for a 700R4.....what one earth could a 700R4 be mated to that would require and extra foot and a half of cable and shield? Does the 700R4 fit some Allison I don't know about?
#185 |
I would put one one big enough to cover the rubber bushing. Something like a fender washer should work. Here's a picture.
#186 |
Damn Yankee
#187 |
Maybe they're not needed, but I believe in OVERKILL on suspension and brake stuff,
#188 |
4WD's have an outer bracket on that shock that "sandwiches" it to the frame...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 06-28-2008 at 04:31 PM. |
#189 |
Junior Member
![]() Join Date: Jul 2005
Ok, this is awsome!
First, you're putting in a full floor. I just bought one at Carlisle and am starting mine. Second you're a vendor in NJ. I didn't know there was a place I could drive to to get parts. I was wondering, if I came up to buy a couple of pieces I need, would it be possible to get a close-up look at this truck? I'm pretty much ok with doing my floor but it would be great if I could see a build up close.
1971 Short Stepside,(sold) 2011 Caprice PPV 1950 Chevy Fleetline Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=302759 |
#190 |
been keeping tabs on this site, like to know how the cab coming, like to see how the doors fit after all the floor sheetmetal was replaced, one day i need to buy (2) doors for my truck, keep up the hard work 7pictures coming
#191 |
Tasty Cakes!
I just got the same KYB shock setup from ECE, and all it came with was the lock washers, so that's all I used. Those shocks have a larger sleeve? than the KYB gas-adjusts that were on my truck before, so maybe that's why they don't use a flat washer? I plan on keeping an eye on everything for a bit after I get it all put back together though. I can just see my front suspension falling off after I hit the switches on the bag setup
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado Last edited by Riveted1; 07-09-2008 at 12:34 AM. |
#192 | |
Damn Yankee
#193 |
Tasty Cakes!
Any new updates?
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
#194 |
Damn Yankee
Not really. I've been out of the office for a week and I'm waiting on the new fuel tank to do the fuel system next. I may come in tomorrow and drill/grind out half a dozen more rivets to get that out of the way.
I did drill the frame for a bulkhead fitting and ran the rearend vent: ![]() |
#195 |
Tot Roddin'
Nice work on the rearend vent.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#196 |
Damn Yankee
#197 |
Does the rear require that fancy of a breather/vent? Or are you just being fancy?
Usually you only see a plain hose right?
#198 |
Damn Yankee
#199 |
Damn Yankee
Started welding everything on the cab up solid.
#200 |
Nice your welder showed up, man he knocked it out in hurry...How'd the doors fit?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-15-2008 at 05:02 PM. |
