Old 06-28-2008, 05:48 PM   #1
SCOTI
SCOTI's Avatar
Rear AirRide 'Strong Arm' Question
Does anyone have the rear ART trailing arms on their truck? If so, I was curious about the measurement from the air bag pad on top of the arm to the rear end 'saddle' that the rear end sits on.
I would like to know the height difference between the two....
Scot
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-02-2008, 11:19 AM   #2
PipsC10
PipsC10's Avatar
Re: Rear AirRide 'Strong Arm' Question
Scot
I can get you the measurements tonight when I get home if you still need them. Not sure what you mean by the "saddle" or where on the bag plate you want the measurements from.
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702
2006 Toyota Tacoma double cab 4x4
PipsC10 is offline   Reply With Quote
Old 07-02-2008, 12:43 PM   #3
SCOTI
SCOTI's Avatar
I want the difference from the pad where the bags sits vs. the pad that the rear housing tubes sit on. So if you put a straight edge on the pad for the rear housing & measured the distance from there down to the pad that the bag sits on (I want to know the height difference between the two).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-02-2008, 06:49 PM   #4
PipsC10
PipsC10's Avatar
OK, I think I got it. I will measure it when I get home and post it tonight. I will also take a photo of what I'm measuring to make sure it's what you need.
Old 07-02-2008, 08:52 PM   #5
SCOTI
SCOTI's Avatar
100% appreciated!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-02-2008, 09:47 PM   #6
PipsC10
PipsC10's Avatar
I hope this is what you needed. Measurement A is 2 1/4 inches and B is 3 3/4 inches. If this is not what you needed, I can take more measurements. I placed a level at the bottom of the bag plate and measured from there to the top of the housing pad from the front and back.
Old 07-02-2008, 10:02 PM   #7
SCOTI
SCOTI's Avatar
That is exactly what I was needing. Thanks alot!
My curiosity was if ART designed the arms w/a 'block' built into them (since many guys add lowering blocks to their stock arms). That 2.25" dimension closest to the bag would seem to indicate that they are in fact designed that way.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-02-2008, 10:10 PM   #8
PipsC10
PipsC10's Avatar
Cool, helping another member out and I too get to learn something!
