Old 06-28-2008, 06:30 PM   #1
Bentblazer
Bentblazer's Avatar
Ignition Switch
Having problems removing ignition switch and bezel. Removed wiring harness. Switch and bezel rotate in dash not sure what to do next. I'm sure its simple, just seem to be missing it. Would also like to be able to put harness back on once out as I sill start and move blazer occasionally. What am I missing?
Bentblazer is offline   Reply With Quote
Old 06-28-2008, 07:25 PM   #2
Alexis
Member since 2000
Alexis's Avatar
Re: Ignition Switch
Edit: deleted everything cause I was wrong
Here is a thread that will give you the anwser.
CLICK ME
Worked first try! Turn switch to acc first, THEN push in paper clip and turn further counter clockwise, pull out with key as you jiggle and hold mouth just so and out it comes!
Alexis is offline   Reply With Quote
Old 06-28-2008, 09:44 PM   #3
Bentblazer
Bentblazer's Avatar
Re: Ignition Switch
Thanks, Knew I had to use a paper clip but wasn't sure about key position, will try in the am. Thanks again
