Old 06-28-2008, 10:05 PM   #1
billsbowtie
billsbowtie's Avatar
how is a good way to put headers on the 67/72 trucks
i started putting some long tube headers on my 68 today that came on a 70 that i parted out. i got the drivers side on from the bottom. but the pass. side is being a pain. i took the starter off and tried to put in up from the bottom but i am hitting lines and stuff trans. & brake lines. and now it looks like the starter needs to be back on before i can bolt the header on. i am starting to think i shouldn't have started this upgrade. thanks for any help.
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 06-29-2008, 12:13 AM   #2
68c10guy
68c10guy's Avatar
Re: how is a good way to put headers on the 67/72 trucks
Pretty sure i took mine out from the top. just takes some time and patience
68c10guy is offline   Reply With Quote
Old 06-29-2008, 12:50 AM   #3
samwise68
FarmBoy.
samwise68's Avatar
If I remember right, when I did mine, I had to loosen the starter to get the collecter past, otherwise there was no interference.
Then bolted the starter up, and then the headers.
Just takes some wiggling and some patience.
Please, put down the BFH, sir...
And in my opinion, they're worth it, simply for the noise factor. But then again, I would think that.
Good luck.
-Sam.
1969 GMC C1500. long fleet.
307. 3 on the tree. 3.07 gears.
Oliver green. Bent and bruised. Daily Driver.
Screw patina... it's a beater...Beaters are cool.
my build thread - Project Homebrew:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993
samwise68 is offline   Reply With Quote
Old 06-29-2008, 02:23 AM   #4
Gray Ghost
Gray Ghost's Avatar
The passenger side has to go in from the top. What brand of headers are they?
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 06-29-2008, 07:03 AM   #5
70GMCer
70GMCer's Avatar
My sbc Hedmans went in from the bottom on both sides. No interference at all.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-29-2008, 01:36 PM   #6
billsbowtie
mine was used they came on a truck i bought eng. was gone when i got it. i think they are hooker brand headers. i will try again maybe monday. thanks for the help.
Old 06-29-2008, 02:53 PM   #7
billsbowtie
drivers side.
Old 06-29-2008, 02:53 PM   #8
billsbowtie
pass. side
Old 06-29-2008, 02:53 PM   #9
67chevyguy
67chevyguy's Avatar
To get my Hedmans in I just unbolted the engine from the mounts and lifted it about and inch and they slid in very carefully, both sides from the top. I didn't have to disconnect anything else.
*edit* now that a think of it they may not have both gone in through the top. Either way though, in my case the starter stayed on I just lifted the engine. *
67chevyguy is offline   Reply With Quote
Old 06-29-2008, 02:54 PM   #10
billsbowtie
pass. side header.
Old 06-29-2008, 03:23 PM   #11
Gray Ghost
Gray Ghost's Avatar
I think when I had my Hedmans I had to raise the block on the passenger side as well. Definitely had to remove the starter entirely.
Kelly
Old 07-01-2008, 12:21 AM   #12
billsbowtie
i got the pass. side on today. but when putting my plugs back in and wiring it back up i notice back plug on drivers side would not go in. p.o. put them in to tite and messed up that plug hole.i think i have a burnt valve on that side anyways so i am going to take the head off and have it redone and retread the spark plug hole. i was getting ready to put my alum. high rise intake and elderbrock carb on it anyway so i will go ahead and fix the head while the eng. is down that far. so it will be a little longer before i get to here how it sounds. but i should have a few more horses to feed when it's done.
Old 07-01-2008, 12:39 AM   #13
basketcase
basketcase's Avatar
Don't forget to richen up the carb with the headers on.
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 07-01-2008, 06:45 AM   #14
Gray Ghost
Gray Ghost's Avatar
I think you'll like what you hear...I sure like mine.
Kelly
