Old 06-29-2008, 01:29 AM   #1
energiesource
how to take cab off with one person?
What tools would i need besides some huge ass hoist to get the cab off? ive put my project on hold just because i cant get the engine and cab off which is stupid, so i need to get this stuff off. i have an engine mount but as for the cab i dunno what to do with it even
energiesource is offline   Reply With Quote
Old 06-29-2008, 01:44 AM   #2
Kayotic
Kayotic's Avatar
Re: how to take cab off with one person?
Search For "Cab Lift". Look for post by ROKCRLN. He has plans for a cab and bed lift.
Kayotic is offline   Reply With Quote
Old 06-29-2008, 02:01 AM   #3
TravisH
TravisH's Avatar
I used a forklift and a couple slings, but my glass was all out
TravisH is offline   Reply With Quote
Old 06-29-2008, 05:50 AM   #4
Billhilly
Billhilly's Avatar
Engine lifter, and some chain to seat belt/cab mount holes from memory.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 06-29-2008, 05:55 AM   #5
abadsvt
abadsvt's Avatar
In my opinion the easiest way is the cab lift from Rockrln. I use it all the time and it is a piece of cake. You do need a cherry picker though.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 06-29-2008, 08:24 AM   #6
Cherry picker, some 2x4s and straps.
Old 06-29-2008, 08:46 AM   #7
thirdstreettito
Resident of Here
thirdstreettito's Avatar
8 rednecks who can lift good.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-29-2008, 10:02 AM   #8
cdowns
cdowns's Avatar
using the engine crane is a very easy way to remove cab// it's possible to do with a floor jack and a bunch of wood blocks too
the whole key to removing the cab or any heavy object is a basic understanding of leverage and an ability to outthink the piece needing to be removed
Old 06-29-2008, 10:36 AM   #9
odog
odog's Avatar
How big are you???? If you don't want to keep the cab just roll it off, other wise get a cherry picker. I had the engine and everything out of mine and just tilted one corner then the other till it came off the frame, but I screwed up the passenger side cabcorner. I had to replace it anyway, but it wasn't the most desireable way
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 06-29-2008, 10:53 AM   #10
energiesource
see if ihad my engine out i could try to jack it up and set it on jackstands and kind of roll the frame out from underneath but the **** is in the way. how much do those cherry pickers run?
Old 06-29-2008, 10:54 AM   #11
ChevyDude
All I did was drill a hole in the middle of an eight foot 2x4. Attach the 2x4 to the bolt on the Cherry picker end, center bolt in cab with 2x4 to the front of the cab, LIFT!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 06-29-2008, 11:00 AM   #12
energiesource
how much does that cab weigh out of curiosity?
Old 06-29-2008, 11:08 AM   #13
odog
odog's Avatar
totaly stripped about 200 but its awkward,
1969 4x4
Old 06-29-2008, 11:10 AM   #14
energiesource
oh awesome then, i guess that cherry picker/engine crane will have to do. is $340 a good price for one of those? its a 2 ton one.
Old 06-29-2008, 11:32 AM   #15
lchall
$340 seems pretty high. I bought an AC Delco Hoist at Oreilly Auto for around $240. You can get cheaper, but I don't like to try and save money on lifting equipment.
The following link has some info on it with picture.
http://www.bencostuff.com/products/j...Engine%20Crane
I would also suggest the cab and lift that others have recommended. I used it on my truck and I thought it worked great. Took the cab and bed off by myself, easy.
He also has plans for a tip/flip dolly that are in his sig. I purchased those as well and can highly recommend. Makes it nice to be able to roll around the cab all over the garage, in the driveway, etc.
Here's a link to the cab/bed lift post.
http://67-72chevytrucks.com/vboard/s...d.php?t=219353
And a pic with the cab lift and dolly.
1967 Chevy SWB
1972 Chevy SWB
1972 Chevy SWB K20 4x4
1991 Ford F-150
2013 Dodge Ram 1500 4x4
lchall is offline   Reply With Quote
Old 06-29-2008, 11:50 AM   #16
energiesource
i dont think i have enough left of my cab to frame supports to put that tip dolly on haha
Old 06-29-2008, 12:43 PM   #17
Bob D
Rolled on Paint Club
Bob D's Avatar
Some chains and a joist:
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 06-29-2008, 02:12 PM   #18
scrapmetalart
Junior Member
A come-along & the rafters of the garage...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 06-29-2008, 02:20 PM   #19
steelhorse
steelhorse's Avatar
Tractor supply has them for around $150 that fold up when not in use.I have sometimes seen them at Sams club but not always.
steelhorse is offline   Reply With Quote
Old 06-29-2008, 02:24 PM   #20
rscam
I rolled the truck out in the grass and pushed the cab to one side slowly until it teetered. I lifted it slowly and it slid off into the grass. It only fell about 6 inches until it hit the grass. Then I just stood it up on its side. I had to replace the corners and rockers so I wasn't worried about damaging them when it hit. It was a little harder to get back on but I did it the same way in reverse. By the way I had the whole cab completely stripped of glass,doors, etc. It was just a shell.
rscam is offline   Reply With Quote
Old 06-29-2008, 11:52 PM   #21
odog
odog's Avatar
Glad I'm not the only one to do that.
1969 4x4
Old 11-13-2008, 12:54 AM   #22
white_paper_180
white_paper_180's Avatar
The! only way
white_paper_180 is offline   Reply With Quote
Old 11-13-2008, 01:22 AM   #23
8mpg
8mpg's Avatar
good ideas guys... Im going to try Bob D's method after painting.
8mpg is offline   Reply With Quote
Old 11-13-2008, 02:17 AM   #24
tdave00
Restoring a 68 SWB
tdave00's Avatar
There you go. What garage rafters can't support 200lbs?
tdave00 is offline   Reply With Quote
Old 11-13-2008, 10:09 AM   #25
thelonerife
thelonerife's Avatar
One in my build thread below
thelonerife is offline   Reply With Quote
