Old 06-29-2008, 05:36 PM   #1
jrdv
jrdv's Avatar
Angry Another Electrical Problem
I put a skip white HEI and a new internally regulated alternator with a wire conversion kit from LMC. I also installed a new factory tach.
The first thing I noticed was when I start the truck (69 GMC 4x4) the tach will spin until the motor starts.
The tach and voltage gauge both jump when I touch the brakes.
I have a battery drain related to the alternator.
My main problem is that the motor will die when I hit bumps in the road.
I crossed a cattle guard last night and the truck died. It will not start, but I have power everywhere. There is 12.5 volts to the distributor, but no spark.
I haven't check the coil yet.
My question is whether there might be something simple that is causing all these problems?
john
jrdv is offline   Reply With Quote
Old 06-29-2008, 07:57 PM   #2
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Re: Another Electrical Problem
I'm sure somebody will chime in but do a search on the HEI modulator. Those tend to go out and cause problems.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 06-29-2008, 08:35 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Sounds like you have something that needs tightening. maybe a ground wire or some other connection
Old 06-29-2008, 10:00 PM   #4
sjarrett71
sjarrett71's Avatar
Sounds silly but check your starter and solenoid. Also the wiring to it.
-Scott-
sjarrett71 is offline   Reply With Quote
