07-01-2008, 05:00 PM | #1 |
Gas guage
I installed a new fuel tank sending unit on my gas tank and hooked up the gas guage to it. But for some reason if I let the truck sit over night in the morning the gas guage reads empty but if I use it in the evening again the gas guage reads were it's suppose to be(it works). Can Someone help or tell me what is the problem.
07-01-2008, 05:02 PM | #2 |
Gas Guage
I installed a new fuel tank sending unit on my gas tank and hooked up the gas guage to it. But for some reason if I let the truck sit over night in the morning the gas guage reads empty but if I use it in the evening again the gas guage reads were it's suppose to be(it works). Can Someone help or tell me what is the problem. I have a 1969 GMC C25 I would also like to know what is the correct way (step by Step) on how to connect the fuel tank sending unit to back of dash
07-01-2008, 05:46 PM | #3 |
Re: Gas guage
Sounds like loose wire or broken wire causing a bad connection when it sits. When you start moving the truck it is causing the wire to move around and thus make connection.
Check all your connections when it reads empty.
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
07-01-2008, 11:18 PM | #4 |
its all about the +6 inches
Re: Gas guage
I don't think I follow quite right.... it moves verses the time of day... when the ignition is off...
or it's slowly dropping but retuns to the correct reading when the key gets turned on. |
07-01-2008, 11:33 PM | #5 | |
Re: Gas Guage
I merged your double posts together.
direct quote from the rules; Quote:
