Old 07-02-2008, 08:12 AM   #1
notahybrid
Power disc conversion and vacuum check
I am hoping to do a power disc upgrade to my 68 c10 in the near future. I currently have manual drum. When checking for vacuum for the power upgrade, where is the best place to connect the gauge on a 250? Also, where will the vacuum line attach when the booster is in?
notahybrid is offline   Reply With Quote
Old 07-02-2008, 11:06 AM   #2
Luvlegs
Luvlegs's Avatar
Re: Power disc conversion and vacuum check
Look below the carb and you can see where the vacuum line is - then up to the booster fitting
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 07-02-2008, 02:28 PM   #3
notahybrid
Thanks for the photo that helps a lot. I am assuming if I do not have a port on the manifold, one could be drilled and threaded?
Old 07-02-2008, 05:07 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You should have a port there.I used the 7 in booster and it seems like I have lots more room.The air cleaner assembly on Luvlegs truck is specifically for the power brake 6 cyl trucks.IIRC he had a bit of a time finding a complete one.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-02-2008, 05:10 PM   #5
Luvlegs
Luvlegs's Avatar
yep - found another one too... just don't have another truck
1972 C10 L6 3OTT
Old 07-02-2008, 07:20 PM   #6
notahybrid
Looks new, any hints on where I may be able to find one for another 6 cyl? I found what looked like a good kit for a 9" from one of the vendors on this site.
Thanks all!
