Old 07-04-2008, 10:15 AM   #1
JMurray
Front Suspension Swap?
I am changing my 68 over to disc brakes on the front. I just aquired the entire front end out of a 85 burb, everything from crossmember out to tires including the powerstering box, pump and prop valve. I am wondering is this a direct bolt in aside from drilling some holes. I am wanting to replace everything from my 68 front end with the 85 burbs including the crossmember and engine mounts. I found this thread but it didn't have a direct answer to this question. I'm sure this question has been aswered before but I can't find it on a search.
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
Happy fourth
JMurray is offline   Reply With Quote
Old 07-04-2008, 10:28 AM   #2
azfab
azfab's Avatar
Re: Front Suspension Swap?
hay dude you shuld have no problem. i used a 79 fromtend on my 68 every thing bolted on, i dint use the box thogh. but its the way to go! also if the rear is sixlug instead of buy axels withch are $500. use a sqare body rear end find a 12 bolt most common are 1o bolts but there out there.
lifes short fabricate as much as you can!
azfab is offline   Reply With Quote
Old 07-04-2008, 11:17 AM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
You may have a slight clearance issue with the power steering box hitting the frame, but that may have just been mine
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-04-2008, 03:18 PM   #4
JMurray
Thanks I was hoping it would be a simple swap. I'm keeping my eyes open for a 5 lug 12 bolt with a posi in it. I'm going to be running steelies with moon caps so I can wait until I find a really good deal on an axle. I seen on some post guys are just re-drilling thier rear axles lug pattern what does this require?
Does anyone know who makes a complete poly bushing kit for the 85 burb front end. Are my rotors going to be 1" or 1.5"
Azfab are you really having to pay $500 for axles? the local scrap yard will sell me 5 lug 12 bolt axles for $50 each.
Old 07-04-2008, 11:25 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Since it came from a Burb they will "probably" be 1 1/4". Measure the rotor thickness to be sure.
Check with Chris at http://www.73-87chevytrucks.com for the part you need.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-07-2008, 06:15 PM   #6
JMurray
Old 07-08-2008, 07:17 PM   #7
azfab
azfab's Avatar
yeah i boght duchman axels there were like 400.00 and i boght new drums. it was around five oh and bearings to.
