07-04-2008, 12:12 PM | #1 |
Master cylinder, which lines go where?
My reservoirs are the same size, does the front port go to the front brakes or back. Front are disc with rear drum, master cylinder is for a 71, I am putting a adjustable prop valve for the rear.
07-04-2008, 02:17 PM | #2 |
Re: Master cylinder, which lines go where?
I'm pretty sure that the resevoirs are backwards. i.e. back resevoir are front brakes and front resevoir are rear brakes.
1968 GMC, 2wd to 4wd conversion, automatic to manual, 4 in custom lift, 36'' military tires, recent 454 upgrade 1979 Pontiac Firebird, mildly built sb 350, t56 trans |
07-04-2008, 02:40 PM | #3 |
its all about the +6 inches
need to know if it is a 1/2 ton or a 3/4 ton
07-04-2008, 02:44 PM | #4 |
You need a disc/drum master cylinder. There is a difference in the volume of fluid moved. The drum style master has a residual vavle that will hold too much pressure on the discs.
Power? |
07-04-2008, 03:09 PM | #5 |
It is a disc drum master, it is also a 1/2 ton.
07-04-2008, 05:13 PM | #6 |
On a 1/2 ton truck the front of the master is the front brakes.
FWIW, 3/4 ton is the opposite. |
07-05-2008, 09:01 AM | #7 |
thanks
