Old 07-09-2008, 10:48 AM   #1
blazer2007
can a lockup 350 be unplugged and work
I have a turbo 350 that I bought but later noticed a 4 prong plug on the dr. side,I guess this a lock stlye,can I still run it without plugging it in,even so I don,t know where to plug it into.Would I use the torque converter that it came with or can I use other or are they the same
blazer2007 is offline   Reply With Quote
Old 07-09-2008, 11:02 AM   #2
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
Re: can a lockup 350 be unplugged and work
A Th350C uses a special converter that wont interchange with a non lock up th350. It will work for a while without the lock up, but the converter will generate more heat from slipping and the clutches will start slipping after some miles. Inevitable heat related failure without the lock up working. Same with 2004R and 700R4 transmissions, you gotta have the lock up working for it to survive much more than a few thousand miles. Well unless you change some things, like the converter itself.
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
Old 07-09-2008, 11:40 AM   #3
Pyrotechnic
Pyrotechnic's Avatar
Is the converter in those real loose ? How did the original non lockup versions survive ?
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 07-09-2008, 04:28 PM   #4
Thumpin455
Thumpin455's Avatar
They arent that lose, but they are not set up the same as the old ones are. Im not entirely sure what the exact cause is or if an axillary cooler will help them live longer. They produce more heat when not locked up and they are designed to be locked up in cruise mode, its not an isolated thing. You can put a non lock up converter in a 700R4, such as a high performance stall converter, but of course it would see limited use and be used with deep gears.
I thought my instructor at tech school was nuts because its "simply" a converter with a clutch in it. Yet every one I have run, and those that someone brought to me where the converter wasnt applying burned up. So personal experience meshes with professional opinion, as well as technical manuals. At least in my case.
Im not sure about the 350C, but the 2004R and 700R4 can both lock the coverter with a single 12v power wire on a switch. You would need to toggle it off when you come to a stop or accelerate hard, but as long as you remember to use the switch it will work.
A much better idea is a lock up controller from an aftermarket vendor, such as the B&M unit I have in my 70 GTO. There are a number of them out there, and also information on which wire to connect. Shouldnt be hard to come up with the right pin for power.
Old 07-09-2008, 10:21 PM   #5
ton*loc
ton*loc's Avatar
where does those wires go to on a stock truck that controls the lock up ?? computer or something ?
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 07-10-2008, 07:04 PM   #6
gmclowsierra
ive been running mine without the lock up for a bout 25000 miles and no issues yet. mine is in an 85 gmc
gmclowsierra is offline   Reply With Quote
Old 07-10-2008, 08:14 PM   #7
Square84
I don't think these pills work
Square84's Avatar
mine shifted like crap with the lock up hooked up so i unhooked it and know drives great shifts fine its in an 84 lwb that is my daily driver and sees ocassional track pass. its been unhooked since 04'.
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 07-11-2008, 03:34 PM   #8
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Mine has been unhooked for several years. I'll get around to hooking it back up one of these days!
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 07-12-2008, 05:54 PM   #9
ton*loc
ton*loc's Avatar
sweet well at least three of you are conferming it dosnt need to be hooked up. that dude up there had me worried thinking my tranny was going to go out !
MMA RECORD 24-5
Old 07-12-2008, 07:43 PM   #10
Thumpin455
Thumpin455's Avatar
Well I lost three of them, maybe you guys just arent making any power.. lol.. j/k
if you have a cooler that will probably help. Not a fan of the 350C in any event
