Old 07-11-2008, 03:23 PM   #1
sqrbdy
sqrbdy's Avatar
Smooth Firewall
Is there a company that makes a smooth firewall for 73-87 trucks?
Ain't Nobody Like a Square Body
sqrbdy myspace
sqrbdy is offline   Reply With Quote
Old 07-14-2008, 02:24 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Smooth Firewall
Not that I am aware of. Pretty simple to do it yourself though.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-14-2008, 05:26 PM   #3
sqrbdy
sqrbdy's Avatar
Re: Smooth Firewall
Thanks for the reply. I was planning on doing it myself, but it would sure be easy if someone made it. Maybe I could make a mold when I do mine.
sqrbdy myspace
Old 07-14-2008, 05:41 PM   #4
COMP
Re: Smooth Firewall
post it back here if you do
COMP is offline   Reply With Quote
Old 07-15-2008, 05:42 PM   #5
EJC78
No Life Like Low Life
EJC78's Avatar
Re: Smooth Firewall
This is what I did
Eric
1978 Chevy Scottsdale
1960 Impala ZZ4
1965 Buick Riviera GS
2011 GMC Sierra Denali
EJC78 is offline   Reply With Quote
Old 07-15-2008, 11:54 PM   #6
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Smooth Firewall
I guess you could call mice semi-smooth.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-16-2008, 12:41 AM   #7
sqrbdy
sqrbdy's Avatar
Re: Smooth Firewall
Did you just fill the holes and leave the factory supports? (I do not mean to discount the amount of effort it takes to do this)
sqrbdy myspace
Old 07-16-2008, 01:13 AM   #8
smashingchuck
Re: Smooth Firewall
pretty much. I cut out most of where the heater box was just below the pinch weld, and did the same on the driver side as well, and had to rebuild the gas pedal area and weld studs to the inside. On the driver side I used pretty thick sheet metal so it could support having the pedal assembly welded to it. All other smaller holes I just filled in one by one with sheet metal, with the exception of the support for the dash, and where the throttle cable comes through. I left the angeled pinch welds on the upper part of the fire wall - those were a can of worms I didn't want to open, plus they are fairly structural. All in all, if I had it to do over I wouldn't change the way I did it. It's just the right amount of "smooth" for me.
78 Build Thread
4Runner Build
Old 07-16-2008, 01:15 AM   #9
stepside454
stepside454's Avatar
Re: Smooth Firewall
nicely done
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
