Old 07-13-2008, 07:31 PM   #1
javadoc
Hey Watch this...
javadoc's Avatar
Fuel Cap Stuck on Truck!
For some reason, the fuel cap on my truck won't release. It's one of those that you put the key in the center and when you turn it, it retracts the 'locking' fingers, or whatever the technical term for them is.
Any way, it will turn a bit but won't come off. My thought is that possibly the system is sealed and now that the tank is nearly empty, there's a good deal of vacuum which could be holding the cap on. Sound plausible?
Any ideas how to make it come loose? I was thinking of loosening up the fuel gauge sender bolts on the tank and seeing if I could relieve the pressure. Anyone had to do that before?
Thanks for any advice, guys!
What have I gotten myself into now?
1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress
2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids
javadoc is offline   Reply With Quote
Old 07-13-2008, 08:10 PM   #2
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Re: Fuel Cap Stuck on Truck!
If it is a vacume, just crack the hose clamps at the filler neck, it wont take much. I am betting the your cap is just worn or gone to crap, in which case a hammer with make short work of it, Or just take a chisel or somthing and pop the tumbler out of it and it will come right off.
kdrodworks316 is offline   Reply With Quote
Old 07-13-2008, 09:32 PM   #3
scotts62
One day...
scotts62's Avatar
Ya try warming it up with a torch J/K
Mine did that same thing to me i ended up using a big pair of channel locks to break it, and bought new one with better vent.
Scott
93 crew cab build
Project 62
Old 07-13-2008, 11:00 PM   #4
javadoc
Hey Watch this...
javadoc's Avatar
Thx for the replies. Yeah, I'm thinking that I need to dig out the channel locks. We'll see what happens.
Old 07-13-2008, 11:15 PM   #5
scotts62
One day...
scotts62's Avatar
Is it a metal or plastic cap?
Scott
93 crew cab build
Project 62
Old 07-13-2008, 11:20 PM   #6
javadoc
Hey Watch this...
javadoc's Avatar
Metal... looks JUST like this one.
Old 07-14-2008, 01:46 PM   #7
MacAttack
283 Drama Queen
MacAttack's Avatar
Yeah, the guy that ripped my truck off had the same problem, cause I still had the keys. Rather than releasing the connector tube, pulling out the neck assembly and simply putting a long screwdriver down to the tabs - while turning the key (which he didn't have) to get the cap off - he just used a mungus pipe wrench to twist the locking gas cap off.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 07-14-2008, 10:13 PM   #8
javadoc
Hey Watch this...
javadoc's Avatar
Great ideas. I think I'm going to have to see about removing the filler neck from the tank. It looks like it's attached directly to the tank with a couple of bolts. Also, a couple of hose clamp-ish operations on the neck itself. I think that the PO had removed the tank recently to paint the cab (it's got fresh white paint behind the tank, and the tank is a nice shiny red), so hopefully the neck isn't hermetically fused to everything.
Old 07-14-2008, 10:55 PM   #9
scotts62
One day...
scotts62's Avatar
Thats cool, maybe it will be easy to get loose once you get into it.. good luck
Scott
93 crew cab build
Project 62
Old 07-15-2008, 03:00 PM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
I would bet the filler neck hose needs replaced.
And if you have too much trouble getting the cap off, heat the tank until the cap blows off from the pressure. Just be sure it's parked outside and that your fire insurance is paid.
And if you're married your wife might want to buy some more life insurance.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-15-2008, 04:45 PM   #11
Phildooney
Phildooney's Avatar
Just think of the dollars you will save on gas if you leave it stuck!
Phildooney is offline   Reply With Quote
Old 07-15-2008, 04:49 PM   #12
MacAttack
283 Drama Queen
MacAttack's Avatar
Ah - you'll be fine. I'm using my old metal neck as a pencil holder on my desk at work. Classic Industries has the rubber hose (extra-heavy-duty) on their site and I found a 1/4" drive ratchet, a universal and a short socket worked perfectly.
Just remember that the old hose has probably become one with the tank and if you give it a good squirt with brake cleaner it will break the bond. Just watch your paint. I loosened my tank straps and that helped me get to everything easier - both out and back in - with the filler assembly.
