Old 02-08-2003, 03:54 PM   #1
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
Need Help with identifing HD Trans/TC
I have a Chevy transmission and transfer case combo given to me quite awhile back that I would like to identify. Transfer case is a heavy cast iron unit with G-99404 cast into the body. It has a steel removable plate below the rear output shaft and has the date code of 6-25-79 cast into it. The transmission bolted to the transfer case is also cast iron and has a removable coverplate on the lower right hand side.
Does anyone have any idea what series of chevy truck this came from and what use/interchange it might have? Any value?
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 02-08-2003, 09:15 PM   #2
racerjim
On the t-case is there 2 rods coming out the front towards the trans?
if so then it is a 205 t-case a good strong unit, if not then it should have a box with a hole in it and levers coming out of the box for the shift selector, if it has that then its a 203 basically a boat anchor as they are not really any good.
the tranny is more then likly a SM465 this should be written on teh drivers side of it right in the middle. its just a regular chev 4spd trans. pretty near indestructable.
hope this helped you out
81 chev 1/2ton 4x4,
4"lift and 38" super swampers.
soon to become a 69.
racerjim is offline   Reply With Quote
Old 02-08-2003, 10:48 PM   #3
racerjim
all depends what is in your 82 now. but you will probably have to modify the d-shaft lengths.
that is a NP205 model tcase. very heavy but very strong.
81 chev 1/2ton 4x4,
Old 02-08-2003, 11:09 PM   #4
82 Silverado 4X
Genuine Chevrolet
Yea, the t-case by itself weighs a ton. In my 82 truck I have the 117mm 4spd with granny and the NP Transfer case that came with the trucks with no hubs. For a daily driver it's OK. I screwed up about a month ago and "gave away" a t-case that came out of an 81 blazer with an automatic that I had stripped down thinking that it wouldn't swap with my manual transmission. This would have been a direct backup for what I have.
George
Old 02-10-2003, 08:24 AM   #5
ZOOMY
George, If you decide not to use them, I am interested in buying them. Dave (920)484-3899 (wi)
ZOOMY is offline   Reply With Quote
Old 02-11-2003, 01:19 PM   #6
Rod
Look like this Np205? Note the casting number... its the same
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-11-2003, 07:05 PM   #7
Slick71
Slick71's Avatar
So does this appear to be an NP-205??? No casting # like the one pictured above, but it looks the same.
1972 Chevy Blazer 4X4
Savannah, MO.
www.thefarmatadair.com
Slick71 is offline   Reply With Quote
Old 02-11-2003, 08:09 PM   #8
Pont
I need another Barley Pop
Pont's Avatar
Yep, that's a NP205 Slick. From what I've learned, the tell tale sign of a 205 is the small idler shaft cover with 3 bolts on the back center of the t-case. I understand that only the 205's have this.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 02-11-2003, 08:33 PM   #9
82 Silverado 4X
Genuine Chevrolet
My NP 205 transfer case
The one I have has a 10 spline input shaft. It has the square plate 4 bolt front output and the cast Aluminum rear output for a slip yoke driveshaft. It was bolted to a 465 4spd. manual transmission. Hopefully here's a picture of it.
George
Old 02-11-2003, 08:40 PM   #10
NAPCO ken
NAPCO ken's Avatar
Those "boat anchor" manual tranny versioned 203s are highly sought after by members of ColoradoK5.com. If you have one, do not throw it away, but instead, advertise it for sale there. They use them for doubler conversions, which basically uses the 203's range box only and mates it to a 205 transfer case.
ken
'58 Chev NAPCO 4x4 short
'60 GMC Suburban 4x4, restored
'60 GMC 3/4T stepside 4x4
'64 GMC Suburban 4x4, restored
'90 Chev Suburban 4x4, dually, ZZ502
'77 GMC Suburban 4x4, one ton axles, 12" lift, 39.5"s
'88 Chevy crewcab dually 4x4, 10" lift, 42"s (x6!)
'03 Jeep Wrangler Rubicon
'79 Chev 3/4 Suburban 4x4, 400-400-203
NAPCO ken is offline   Reply With Quote
Old 02-11-2003, 08:40 PM   #11
Pont
Pont's Avatar
That definitely looks like a 205, I've just never seen one with that long output housing. It may be common, I've just never seen one. If your interested in getting rid of that shifter knob, let me know.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
Old 02-11-2003, 08:42 PM   #12
NAPCO ken
NAPCO ken's Avatar
That 205 version with the long slip yoke output is a 1980 version...ALL GM trucks in 1980 used the 205.
ken
Old 02-11-2003, 09:16 PM   #13
Showme-K-20
Like NAPCO Ken said, the 203 is worth holding on to for the doubler that is popular with the CK-5 bunch. Plus, if it's one that was bolted to a 465 manual transmission, it is rare.
Bob
Showme-K-20 is offline   Reply With Quote
Old 02-12-2003, 04:59 PM   #14
82 Silverado 4X
Genuine Chevrolet
I've heard the term "doubler" before. What exactly is it and what does it do?
George
Old 02-12-2003, 05:23 PM   #15
NAPCO ken
NAPCO ken's Avatar
A "doubler", made by ORD (Off Road Design) of Colorado, uses an adapter to mate the range box section of a 203 transfer case in between a 465 trans and 205 transfer case, or in between a TH400 & 205, or TH350 & 205, etc. They have quite a few kits available. The nice thing is you get a two low range ratios, 2:1 and 4:1 thru the range box of the 203. They're pretty cool and bulletproof. Check out: www.offroaddesign.com
ken
Old 02-14-2003, 01:10 AM   #16
1976K5CHALET
1976K5CHALET's Avatar
George...i see your list under you signature includes a 77 K5 Chalet....do we have pics of that unit at our web site...www.blazerchalet.com????
1976K5Chalet
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
