Old 07-16-2008, 08:26 PM   #1
SkylineNXS
SkylineNXS's Avatar
Sorry for askin again, ignition removal?
Hey guys, i know we've discrussed this many times, but i cant find the threads anymore, i scrolled all that were still alive and searched and couldnt find them. How exactly do i remove the ignition cylinder from the gauge bezel so i can remove the whole thing from the truck? Thanks....o, its on a 66...not that thats needed but....
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 07-16-2008, 08:33 PM   #2
Anthony Fremont
Anthony Fremont's Avatar
Re: Sorry for askin again, ignition removal?
Put the key in and turn it all the way to the left (accessory position). Then take a paper clip and insert it into the hole and push the pin down. While doing this, take your third hand and turn the key further to the left. The lock cylinder should come right out and then you can unscrew the outside ring.
'66 GMC Custom Fenderside LWB
'90 IROC - L98
'97 1200C Sportster
Anthony Fremont is offline   Reply With Quote
Old 07-16-2008, 08:57 PM   #3
SkylineNXS
SkylineNXS's Avatar
ok thanks man, appreciate it, also, for the headlight switch, i know u push the button on the underside to get the knob to come out, but what position does the light switch need to be in for that knob to come all the way out, it wont seem to do it for me...
BRAD
Old 07-16-2008, 09:44 PM   #4
63sbssbbw
UCA63
63sbssbbw's Avatar
IIRC in the off position
It should slide right out
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 07-16-2008, 11:20 PM   #5
SkylineNXS
SkylineNXS's Avatar
Yea finally got the stupid thing out, actually it was in the on position, hmm...o well, except now i cant get the retainer ring that holds it in to loosen, i dont know what to use...can get it with anything i have, im gonna have to like grind it off or somethin, unless there is some way that i can get the entire cluster out without removing the switch?
BRAD...
Old 07-16-2008, 11:50 PM   #6
joe231
joe231's Avatar
i use an extremely large flat screwdriver, or flat tipped prybar
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-17-2008, 12:07 AM   #7
SkylineNXS
SkylineNXS's Avatar
Yea the sad thing is ive tried those, and nothing, idk who put it in there, but they somehow tightened it really tight or got it jammed..idk...
BRAD
