Old 07-16-2008, 10:35 PM   #1
pat
pat's Avatar
68 front end rebuild
Hey guys.
I've got to replace my power steering gearbox, and I for some reason never got my front end aligned, so now I need new front tires-very bad wear inside.
Anyway, I figured now would be a good time to do what I should have done when my truck was all torn apart, rebuild the front suspension.
I replaced the upper and lower ball joints during the rebuild, but nothing else.
What parts do I really need to get to rebuild the front suspension?
It doesnt feel tight, so I'd like to fix it.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 07-17-2008, 12:23 AM   #2
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Re: 68 front end rebuild
I’m in the process of doing a full front end on my 79. Here’s my list hope it helps:
Control arm bushings
Lower Ball Joint
Upper Ball Joint
tie rod ends
Idler arm
Shocks
Pitman Arm
Gear Box (rebuild)
Stabilizer
Sway Bar
I’m also making new control arms, when I pulled the bushings on mine the mounts were shot. And a lot of people say you don’t need the stabilizer or sway bar but they make the ride nicer.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 07-17-2008, 02:36 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Check out ECE, they offer a complete front end rebuild kit, all MOOG parts for around $575. A little high, but if you price the parts at your local O'Reilly's it will be over $600+.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-17-2008, 03:32 PM   #4
pat
pat's Avatar
I dunno, doesnt seem as bad as I thought. For 2 inner and 2 outer tie rod ends, 2 adjustor sleeves, an idler arm, a pitman arm, 2 front control arm shaft and bushing kits, and 2 rear control arm shaft and bushing kits, it only totals to about $330, tax included.
Old 07-17-2008, 03:37 PM   #5
pat
pat's Avatar
and my shocks are pretty new, I have a sway bar with new bushings, and I already have a rebuilt pwr steering box
Old 07-17-2008, 09:28 PM   #6
79gmcsierragrande
I bought everything from Amazon, spent $230 for everything you listed accept for the control arm shafts. All Moog parts.
