Old 07-17-2008, 08:31 AM   #1
gearhead1968
gearhead1968's Avatar
My Camaro Headers Install pictures
Headers seem to be about the most asked about question on this board. I just installed a set of Headman Elite full length Camaro Headers on my lowered 1976 C-10. The Camaro headers fit 1967-1981, here are some photos so you can see the clearance. The passanger side went in easy from the top, the drivers side I had to go from under neath. I still need to hook it up to my new exhaust H pipe.
1976 C-10 shortbed 2wd (work in progress)
Mods:
Stock 307, 700R4 Transmission, Hurst Pro-Matic shifter, 2100 rpm stall converter, Headman Elite 1 5/8" headers, H-pipe, 2 1/2 exhaust through Magnaflow mufflers, 3.73 Motive gears, superior axels and Eaton Posi carrier
http://www.cardomain.com/ride/3136537
gearhead1968 is offline   Reply With Quote
Old 07-18-2008, 11:52 AM   #2
Richard D
Richard D's Avatar
Re: My Camaro Headers Install pictures
How are the '82-'87 different? I have an '87 and want to put headers on it. Someday it will be bagged and I don't want them to drag.
Richard D is offline   Reply With Quote
Old 07-18-2008, 12:24 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
67-81 is the year app for the camaro headers
MylilBowTie is offline   Reply With Quote
Old 07-18-2008, 01:27 PM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
will this setup work on a 72 as well?
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 07-18-2008, 04:53 PM   #5
shrtbx
im curious to know whats the difference between getting headers specifically made for the truck as oppose to getting camaro headers. Is it a cost thing?
shrtbx is offline   Reply With Quote
Old 07-18-2008, 05:00 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Car headers do cost less. However, fitting for lower trucks is ideal. 3/4 length and some full length headers don't drop below the frame rails. Exhaust is nicely tucked up.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 07-18-2008, 05:00 PM   #7
COMP
is for me and my 77
COMP is offline   Reply With Quote
Old 09-14-2008, 03:11 PM   #8
Low84
Low84's Avatar
Wow, these do have a lot less hang than the truck headers. Just one question for those running these headers. Have you had to buy a heat shield for the starter or do they hold up pretty well with the headers being that much closer?
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 09-14-2008, 08:52 PM   #9
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I don't understand why you used a camaro application for full legth headers. Every company makes full length headers for our trucks... its the 3/4 length ones that are harder to come by.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-14-2008, 09:04 PM   #10
gearhead1968
Because the full length truck headers hang down way to low and since my truck is lowered the truck headers are very close to the ground.
Mods:
Old 09-14-2008, 11:29 PM   #11
andresco50
andresco50's Avatar
Hey nice headers, they're powder coated???
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 09-15-2008, 08:09 AM   #12
gearhead1968
Thanks! Headman calls it thermal coating, I guess it is very similar.
Mods:
