07-17-2008, 09:13 PM | #1 |
Junior Member
Ideas for cleaning my alternator......?
I'm detailing my engine and I was wondering.....How do I clean my alternator without trashing it? Any ideas?
"A man's got to know his limitations." - Dirty Harry _______________________________________________ 1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker |
07-17-2008, 09:16 PM | #2 |
72 Chevelle Club
Re: Ideas for cleaning my alternator......?
Fine wire wheel on a bench grinder will clean it up nice.
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
07-17-2008, 09:36 PM | #3 |
Junior Member
Thanks, Bob. I already did some wire wheel work and that did help some but it's still kind of greasy. How can I remove the grease without trashing the insides?
07-17-2008, 09:37 PM | #4 |
try laquer thinner on a rag... thats always what i use to degrease my small parts..
07-18-2008, 01:00 AM | #5 |
Lemme show you something!!
I've actually removed the 3 screws that hold the cases together, pulled out the armature and removed the regulator, rectifier, and outside winding....basically gutted the whole thing. It's really not that complicated in there- take pictures so you know how things are oriented @ reassembly. Once tore apart- degrease as normal, hit it with a wire wheel on a bench grinder and then spray "detail gray" from Eastwood.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
07-18-2008, 01:55 AM | #6 |
i would not use laquer thinner as it might screw up the armature/ however kerosene or diesel wont and with a stiff brush will clean it up nice
07-18-2008, 02:11 AM | #7 |
If you are going to take it down to the bare cases I'd use Grease Eater to clean therio cases and then replace the rear bearing and reassemble the alternator.
I've thought about using either McGuire's or Griot Garage aluminum wheel cleaner on a set of spare cases to see what they look like too. I wouldn't use a wire wheel on the cases as it will mar the finish. I've got a stack of old alternators here that are headed for the rebuilder as cores or to the scrap yard in a few days so I might play a bit at cleaning up a couple of cases to see what happens. Last edited by mr48chev; 07-18-2008 at 02:13 AM. |
07-19-2008, 01:12 AM | #8 |
Go to your local hobby shop and get some "Pure". It's a motor cleaner for RC car motors. It will not hurt the epoxy on the windings, or any other electrical components. We use it on our slot car motors to clean the excess oil & brush dust out of them. It works great. And these little motors see in excess of 75,000rpm regularly. Some up to 100,000rpm.
Whatever you use, just be sure to oil the bearings before you start using the alt. again. Or it might chew one up fairly quickly. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
07-19-2008, 01:24 AM | #9 |
there should be a small hole at the back of the alternator. use a paper clip to secure the brushes. take it apart and clean it with an acid formula. it is easy to dissasemble and reassemble
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
07-19-2008, 11:01 AM | #10 |
Junior Member
Thanks for all of the ideas, guys. I've got some chicken going in the smoker this afternoon so the alternator should make a good project while I'm cooking. I'll let you know how it turns out (the alternator that is; I KNOW how the chicken is going to turn out )
08-24-2010, 08:43 PM | #11 |
how did the alt turn out ? I want to do the same thing ? Crc makes a electric motor cleaner could i use that ?
