Old 07-18-2008, 06:40 PM   #1
1Low53Burb
1Low53Burb's Avatar
Can you run without your dust covers?
On your front wheels, your dust covers for your wheel bearings, do you have to have them? The new wheels I have for the '67 work, but I can't put the center caps on without removing the dust covers.
1Low53Burb is offline   Reply With Quote
Old 07-18-2008, 06:44 PM   #2
1972 C-10
1972 C-10's Avatar
Re: Can you run without your dust covers?
I would say no. All the grease would just sling all over the place.
Corey.
1972 LWB FLEETSIDE.
1972 C-10 is offline   Reply With Quote
Old 07-18-2008, 06:50 PM   #3
1972 C-10
1972 C-10's Avatar
Oh, and the life of your bearings would be dramatically reduced due to lack of grease and dirt and debris getting in there.
Corey.
1972 LWB FLEETSIDE.
Old 07-18-2008, 07:05 PM   #4
1Low53Burb
1Low53Burb's Avatar
Never mind. Dumb question and even after I took them off the ceneter caps still hit the nut.
Oh well.
Old 07-18-2008, 08:05 PM   #5
straitnate14
straitnate14's Avatar
ya I ran into this with mini moon's I did all the work to make snap on mini moons fit my rallys and then found this out, this was after about 2 hours of welding little tits on the wheels for the snap on moons to grab onto, it sucked
ΜΟΛΩΝ ΛΑΒΕ
straitnate14 is offline   Reply With Quote
Old 07-18-2008, 08:26 PM   #6
70c10
67-72 Addict!
70c10's Avatar
What kind of wheels are you using?. Maybe you can use a spacer for the center cap?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-19-2008, 01:30 AM   #7
72BLUZ
72BLUZ's Avatar
i know a man who is on this board that ground down the hub to make his center piece fit and kept the factory grease cap
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 07-19-2008, 10:33 AM   #8
LONGHAIR
If a 1/4" would cure your problem, a simple wheel spacer should do. Cheap, easy, very little adverse effect.
LONGHAIR is offline   Reply With Quote
Old 07-19-2008, 10:40 AM   #9
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Get a b.m.f.h. and flatten them. ;-)
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 07-19-2008, 10:45 AM   #10
1Low53Burb
1Low53Burb's Avatar
A BMFH won't help because the nut still hit's with the cap off. I'm thinking of changing rims. I might be selling these.
Old 07-19-2008, 11:19 AM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I agree. I tried making the dust caps a little "shorter" but the axle stub contacted the back side of the cover.....
I believe a spacer is a good point, but just enough of one to create the space you need. 1/4-inch would be too much. Can you get one that is only 1/8-inch?
I'm going to use a different cap on my Rallye's. Don't want to, but don't like the small blip in the center of my police caps.
Member Nr. 2770
