Old 07-19-2008, 10:55 PM   #1
VanceH
Loving the Jimmster
VanceH's Avatar
differances in small block intake manifolds??
Ok i went to a swap meet and bought a small block manifold. I went to take the old one out(cast) and it seems to be different. Mine in the 67 has a oil filler thru the front of the manifold the new one does not? Other than that they look alike. Did i mess up or is there something i am missing.
thanks
Vance
VanceH is offline   Reply With Quote
Old 07-19-2008, 11:08 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: differances in small block intake manifolds??
they did away with that in 69. If you just install valve covers with an oil fill hole, a breather, and a PCV, then you'll be way ahead of the game. The PCV is a smog item that does only good things to your engine. (the oil fill was also a vent for the old road draft system which was replaced by the PCV in trucks in 69)
Old 07-19-2008, 11:18 PM   #3
VanceH
Loving the Jimmster
VanceH's Avatar
Thats one down and i thank you!!! now after looking more my old manifold has a bolt hole for my altinator barcket on the right face (as you stand in front), the new intake has a bolt hole on the top left? New braket?
Old 07-20-2008, 10:42 AM   #4
VanceH
Loving the Jimmster
VanceH's Avatar
Here is a pic of the new manifold. What is te hole on the back left?? the old one does not seem to have this??
thanks
vance
Old 07-20-2008, 11:35 AM   #5
msgross
msgross's Avatar
That far left hole upper is for a vacuum port. You can plug it off with a screw-in plug or use it for a vac gauge/brake booster etc..
Some newer intakes also have the area that can be drilled out to place that old oil filler neck into. I have thought about adding one again but just went ahead and bought a breather for the valve cover. If your valve covers don't have holes then you have another issue.
also make sure that your old thermostat housing bolts down all the way before you add silicone. My edelbrock intake didn't want to take mine, but a newer one fit... could have been the helicoil that I found in it as well...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-20-2008, 11:46 AM   #6
VanceH
Loving the Jimmster
VanceH's Avatar
Thank you but what about the flat spot on the rear left? not sure what that is
Old 07-20-2008, 11:55 AM   #7
msgross
msgross's Avatar
looks like maybe an area for a divorced choke. My 68 had one kinda like it, there is another piece that bolts onto that. it would have a coil inside that reacts to the heat of the intake and moves a bar to adjust the choke.
Not for sure but that's my guess...
The Garage:
Old 07-20-2008, 12:09 PM   #8
fine69
fine69's Avatar
You bought a manifold for a 70's engine. It has the EGR (exhaust gas recirulation) spot. You will need to install an EGR valve. Or a blockoff plate.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 07-20-2008, 12:17 PM   #9
VanceH
Loving the Jimmster
VanceH's Avatar
The amount of information on this board should be illegal!!!!! Thank you for your help i will just get a block and shut that off.
Thanks again
Old 07-20-2008, 12:18 PM   #10
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: differances in small block intake manifolds??
The flat spot is for an EGR valve, or an EGR block off plate.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 07-20-2008, 12:32 PM   #11
msgross
msgross's Avatar
after looking at it again my divorced choke mount is directly beside the carb.
The Garage:
Old 07-20-2008, 01:55 PM   #12
Longhorn Man
The block off plate can be made easily with minimal fabrication, or, you could probably go to edelbrock's www and see if they sell it alone, I had picked up a new performer back in 2000 and it came with the plate.
Old 07-20-2008, 04:38 PM   #13
VanceH
Loving the Jimmster
VanceH's Avatar
Very nice everyone, i went to autozone and ordered a blank for that hole, and about 150 bucks for everything else i need to get this done, as soon as it cools off i am going to start.
thanks again for all the help
vance
Old 07-21-2008, 12:20 AM   #14
VanceH
Loving the Jimmster
VanceH's Avatar
I spent this evening taking off the old manifold and putting the new one one, i still have the carb to finish up Monday night but hope to have it back running by Tuesday.
Thanks again for all the help
vance
Old 07-21-2008, 02:32 AM   #15
fine69
fine69's Avatar
Anytime Vance. Thats what we are here for.
Board member #6
