Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-18-2008, 06:26 PM   #1
ed2552
ed2552's Avatar
65 C60
Dad just bought a 1965 C60 Grain truck with an I6, 4 spd and a 2 spd rear end. It has 51000 orig miles, and is in excellent condition, and has a 15 foot box, and all lights and gauges work. What was offered in these trucks for motors as far as the Straight 6? It is a really nice truck, and has lots of power. It also needs a seat cover, is it the same as the pickup seats? I know but it is in the shed and I'm exhausted from being at camp all week, so maybe this weekend. Thanks for all the input.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 07-19-2008, 11:10 PM   #2
ed2552
ed2552's Avatar
Re: 65 C60
TTT, will have pics tomorrow, for sure Monday
Old 07-20-2008, 12:48 AM   #3
Captainfab
60-66 Nut
Re: 65 C60
I would say it is most likely a 292....that's what's in my '63 C60. Yeah they're not bad for power until you start pulling some serious weight. But then having 10 gears always helps.
Old 07-20-2008, 01:14 AM   #4
ed2552
ed2552's Avatar
Re: 65 C60
Mine has 8, and most of the time you use 6 or 7. Was it the 292 that had offset mounts? My dad said that they had bigger Straight 6's for the trucks, and that they went up to 400CID. He may have been thinking of the GMC V6's as well. It does have the offset mounts and it is fairly big. We need to do some maintenance to it. What should all be done? I know, oil, filter, clean and re-oil air filter, plugs, wires, Dizzy cap, etc. what else? What is availability on cartridge style oil filters? Should we convert to spin-on type? It is midnight, sorry if this may be a little hard to read. Thanks in Advance.
Old 07-20-2008, 02:39 PM   #5
MXmaniac
MXmaniac's Avatar
Re: 65 C60
Yes, the 292 has offset mounts. The passenger side motor mount is in front of the fuel pump on the 292. It also has 6" tall pushrod covers on the passenger side, as opposed to 4" on the 194, 230, and 250. The 292 was the biggest six Chevy made.
1969 C20: 292 L6, SM465 4-speed, Eaton HO52 4.56
MXmaniac is offline   Reply With Quote
Old 07-20-2008, 04:30 PM   #6
greg64
greg64's Avatar
Re: 65 C60
I'd agree with all of MX's info. The 4 speed tranny is likely an SM-420. Besides the obvious clean up stuff you mentioned, you might want to look at Pertronix or a later HEI distributor to get rid of the points.
Good luck with your project, I want to see pics as I like the heavy stuff.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 07-20-2008, 09:27 PM   #7
ed2552
ed2552's Avatar
Re: 65 C60
Sorry, forgot to take pics today, will tomorrow. I like the truck, it looks like the 292, it has offset mounts, and the pump is behind the pass. mount. I may look into the HEI, but it runs great as it sits, i will have new plugs and wires on this week, but what would be a good oil to put in, and what is the filter? Is it a cartridge or spin on and what is anyone's opinion if it has the Cartridge, and as i said before, what is their availability?
Old 07-21-2008, 12:09 AM   #8
ed2552
ed2552's Avatar
Re: 65 C60
Thanks, but it is more of the matter of doing some maintenance work to get it in tip top shape. We plan on using it to haul scrap, as well as an occasional load of water, and we may weld a hitch on and use it to haul really heavy loads that we don't want to put on our pickup.
Old 07-23-2008, 11:42 AM   #9
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: 65 C60
There is a big issue with modern motor oil. They do not have enough zinc to properly lubricate a non-roller camshaft. Read this thread, it is reasonably up to date. flat tappet cam lube
I have been running the newer oil, but am adding a bottle of assembly lube with the zinc.
Your oil filter should be a spin-on and available at any parts store.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-24-2008, 09:13 AM   #10
ed2552
ed2552's Avatar
Re: 65 C60
What about Rotella T diesel oil, or tractor oil? Doesn't that have more zinc? They always ran tractor oil in everything back when my dad was younger, trucks, cars, etc, because they bought it in 55 gal drums. Would that be better than standard motor oil?
Old 07-24-2008, 10:40 AM   #11
justcuz
justcuz's Avatar
Re: 65 C60
Yes tractor oil (for diesels I presume) will be fine. The HEI is an easy and cheap swap. The oil filter if it is a canister type should be availble at your better parts stores (Napa) or at a truck stop/shop where they do repair work.
justcuz is offline   Reply With Quote
Old 07-24-2008, 11:02 AM   #12
joe231
joe231's Avatar
Re: 65 C60
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-24-2008, 02:33 PM   #13
ed2552
ed2552's Avatar
Re: 65 C60
Originally Posted by joe231 View Post
I know, but it is in the shed, and dad doesn't trust me to drive it much yet, and i respect that
Old 07-24-2008, 02:34 PM   #14
joe231
joe231's Avatar
Re: 65 C60
CHEVY ONLY
Old 07-24-2008, 02:41 PM   #15
ed2552
ed2552's Avatar
Re: 65 C60
Lol
Old 07-24-2008, 07:00 PM   #16
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: 65 C60
According to the article, the newer Rotella T does not have enough zinc. If you have some older oil, it will be okay.
Fred
Old 07-24-2008, 07:35 PM   #17
ed2552
ed2552's Avatar
Re: 65 C60
Idk what we have, we have some tractor oil, will that have some more zinc than standard oil?
Old 07-25-2008, 11:21 AM   #18
justcuz
justcuz's Avatar
Re: 65 C60
Rotella T 30w was purchased by me yesterday and it says it is rated for SJ and older vehicles. The articles linked above still say that it has enough zinc. I would think it would be OK for engines that are already broken in. I use it in my older stuff with flat tappets. I would definately overprotect a new engine though during the break in period.
Heres a thought, how much zinc does ATF or gear oil have in it? Since it is not exposed to emissions equipment the emissions standards may not apply. The operational parameters of both are probably more severe than an engine, why could we not augment our engine with a little (8 or 16 oz.) of ATF or gear oil?
Old 07-27-2008, 10:17 PM   #19
ed2552
ed2552's Avatar
Re: 65 C60
We have an appx year and a half old 5 gallon pail of Rotella, so we are good on that, what was the date where it switched?
Old 07-27-2008, 11:48 PM   #20
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: 65 C60
No one knows for sure, the manufacturers won't say.
Fred
Old 08-07-2008, 10:14 PM   #21
ed2552
ed2552's Avatar
Re: 65 C60
Ttt
Old 08-08-2008, 03:52 PM   #22
ed2552
ed2552's Avatar
Re: 65 C60
PICS!!! I also got to drive it, as well as haul a few loads of compost and other stuff, so it was fun.
EDIT: Pics Updated
Old 08-08-2008, 05:16 PM   #23
justcuz
justcuz's Avatar
Re: 65 C60
Dang, nice truck! How did it manage to stay in such nice shape for 40 years?
Old 08-08-2008, 07:29 PM   #24
joe231
joe231's Avatar
Re: 65 C60
if that isn't a testament to these trucks, dunno what is.
43 years old and still a work horse!!
thanks for the pictures
CHEVY ONLY
Old 08-08-2008, 07:32 PM   #25
ed2552
ed2552's Avatar
Re: 65 C60
was owned by a guy who took meticulous care of it. We just put in plugs, put in a new oil and filter, and cleaned the air filter. We need to replace the valvecover gasket, as well as oil pan and rear end gaskets.
