Old 07-20-2008, 09:28 PM   #26
SilveradoDude
Re: Choosing a Distributor
Originally Posted by 85SBC400 View Post
and it never did this before correct?
grab your multimeter, and check the ohm's from that wire to a ground and see if you have a short or not.
No never. I pulled the entire wire it had no cracks or frays whatsoever.
The ALTERNATOR was getting red hot and transferring the heat thru the wire. I pulled the alternator and will have it tested tomorrow but other than that I am lost.
SilveradoDude is offline   Reply With Quote
Old 07-20-2008, 09:40 PM   #27
85SBC400
the alt. itself might grounding internally......good chance thats it i recon. too bad you dont have a buddy same alt. you could try out.
85SBC400 is offline   Reply With Quote
Old 07-21-2008, 09:03 AM   #28
SilveradoDude
Exclamation Re: Choosing a Distributor
Well the alternator tested "fine" it put out more than enough amps. Still wondering about any voltage regulator inside though.
Tell me, the current wiring setup that I had on my truck for the alternator was the main alternator red wire, the primary ignition wire from the fuse block and a red wire from the junction block all joined by a connector.
Old 07-21-2008, 03:10 PM   #29
SilveradoDude
Old 07-22-2008, 05:53 PM   #30
SilveradoDude
I put on a reman alternator and a new thicker gauge (10) alternator wire just to double check and it would still overheat after a minute. I checked the pink ignition wire and didn't see any fraying or cracking. Again the distributor is the only difference in the equation here.
Old 07-22-2008, 08:32 PM   #31
COMP
i have no clue
COMP is offline   Reply With Quote
