Old 07-21-2008, 12:39 AM   #1
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Are these '72 Big block perches?
Found these cheap- I know they are worth some coin if they really are for the '72 only BB.
Can anyone ID without a doubt? I don't want to spring for them if they are '73- up.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 07-21-2008, 01:18 AM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Are these '72 Big block perches?
yes they are the 72 towers! Here's is a couple of picture of a set I had.
Livrat is offline   Reply With Quote
Old 07-21-2008, 01:38 PM   #3
71 super
71 super's Avatar
hard to tell from your picture, but 73 up the holes are further apart in relation to the center rib. you need to get a pic. of the top view, also check to see if they have the clam shells to go with them. hope it worksout that they are 72 mounts as you can turn a few bucks on them if they are.
71 super is offline   Reply With Quote
Old 07-21-2008, 06:33 PM   #4
70rs/ss
70rs/ss's Avatar
The tell tale sign is the humps, on the top rail part, 72 only have one hump and the 73 and ups have two humps (bumps if you will). So those are the 72 only's.
70rs/ss is offline   Reply With Quote
Old 07-21-2008, 08:39 PM   #5
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
I told the guy I wanted them, might get them tomorrow night. Aren't the clamshells the same as ho- hum 73- up parts? If so, I can find those by the dump truck load
Thanks for the help everyone
Old 07-21-2008, 09:37 PM   #6
Hart_Rod
Hart_Rod's Avatar
Here's everything bolted together. They're for sale if anyone needs them.
Hart_Rod is offline   Reply With Quote
Old 07-22-2008, 12:33 PM   #7
70rs/ss
70rs/ss's Avatar
Yeah the clamshells are all the same, if you find an old set, energy suspension sells a urethane bisket to replace the old rubber part, just seperate the clamshell (riveted together usually) and install it, sweet find!!
BTW HARTROD how much??
Old 07-22-2008, 11:45 PM   #8
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Got 'em. Both are stamped Demco, one numbered 757, the other 758. GM must of had an outside vendor for them?
Old 03-06-2022, 10:55 PM   #9
nothingstaysstock
does anyone know were i can buy a set of the bbc clam shells mine are shot and i can only find the 4 bolt ones or the realy expensive energy suspension inserts. i found a set of 3 bolt ones from ictbillet but the Dimensions are all wrong.
nothingstaysstock is offline   Reply With Quote
