Old 07-16-2008, 10:35 PM   #201
RaceAGMC
RaceAGMC's Avatar
Re: project INCREDIBLE HULK 6.2L with 6L80E
Ok, couple questoins about the trans cooler...First, how well do they work compared to the in radatior ones like stock? Second what size is it? And where do you get your braided lines and fittings? I am looking to do this mod on my truck, and i see you have done it to a couple ones u have built. Thanks and keep up the good work.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 07-16-2008, 11:23 PM   #202
lyrikz
PITbut
lyrikz's Avatar
i would also like to know this.
lyrikz is offline   Reply With Quote
Old 07-17-2008, 03:23 AM   #203
lofly'a
lofly'a's Avatar
me 3
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 07-17-2008, 06:47 PM   #204
68 short step
it is a 18" dual row cooler, can be got from summit, jegs, ebay, etc.....
i use -6 AN fitngings and -6 braided lines, these too came from summit/jegs......compaired to the "traditional" rad. mounted ones
this cooler is designed to disapate heat by haveing BOTH internal and external heat dissipating fins also this heat sink design produces high heat transfer with minimal airflow... unlike the traditional radiator mounted ones..... haveing said that it is designed for a non-lockup converter trans cooling needs, so with a lock-up converter, it should work out really well..
68 short step is offline   Reply With Quote
Old 07-17-2008, 09:17 PM   #205
RaceAGMC
RaceAGMC's Avatar
I was thinkin about putting this on my 4L80E, so it'll be good?
Old 07-17-2008, 11:06 PM   #206
68 short step
should be good, yes.
Old 07-17-2008, 11:08 PM   #207
68 short step
a little progress to report on the hulk.....got the trans tunnel fabbed up......
Old 07-17-2008, 11:10 PM   #208
msgross
msgross's Avatar
why not just kit a "high hump" and bolt it in?
nice truck though
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 07-17-2008, 11:26 PM   #209
71Hulk
because i wanted one customade!
you'll see why later!
71Hulk is offline   Reply With Quote
Old 07-20-2008, 10:51 PM   #210
68 short step
got the wire harness fitted in the old vent hole......it fits nice and will look great tucked under the dash...
Old 07-21-2008, 12:10 AM   #211
Riveted1
Tasty Cakes!
Riveted1's Avatar
I tried to look back and see if you said anything, but there is sooo much stuff to look through! Did you leave the outer part of the air vents open to allow for drainage? Or do you have some way of cleaning em out? Just wondering since you blocked them off from the inside. I do like how you mounted your fuse block, looks sharp!
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 07-21-2008, 08:50 AM   #212
68 short step
yes i left a section open for drainage/debris, ill snap some pics of this
Old 07-21-2008, 01:34 PM   #213
Riveted1
Tasty Cakes!
Riveted1's Avatar
Originally Posted by 68 short step View Post
debreix
Are you French?! J/k.... Pics of that area would be cool. You've got me thinking now. My kick panels are shot, so I might just weld a solid sheet of metal in there and call it a day.
Old 07-21-2008, 04:00 PM   #214
68 short step
no im just a terrible speller....its fixed now
Old 07-21-2008, 04:50 PM   #215
71Hulk
AX ME HOW I KNO DIS!!!
Old 07-21-2008, 05:26 PM   #216
msgross
msgross's Avatar
that's a nice little mod.
WIth the shape that mine are in I might do the same, but I would have to be running A/C since I will have no other ventilation...
Whats the plan for the wires through the firewall?
The Garage:
Old 07-21-2008, 10:08 PM   #217
68 short step
here are the drainage holes...the is the pass side (all finished up... and the DR side about to be welded in and how it looks from the inside,,,,
Old 08-16-2008, 12:06 AM   #218
68 short step
getting some progress....
got a head start on the wiring of the truck....im gonna run the wires for the air ride sensors through a bulkhead ,in the cab, to the air ride computer....also got the electric brake system (no vacuum booster), and started to moc it up.....but before i can install in, i neeed to make the driver side firewall smooth and symetrical with the pass. side......also still chipping away at the dash...
Old 08-16-2008, 03:12 AM   #219
Riveted1
Tasty Cakes!
Riveted1's Avatar
Lookin good! Another question about the air vent/cowl area. Since you have the air vents blocked off, couldn't you have just left the whole bottom of the cowl area off? Just asking b/c it seems like trash could still get caught it there. If it was completely open it would be more likely to just fall out. I think your way will work fine, b/c I'm assuming your ride won't be parked under a tree much. I'm just brainstorming for myself...
Oh and what is that electric brake setup u have?
Old 08-16-2008, 12:16 PM   #220
pcorriveau951
pcorriveau951's Avatar
68 short step wheredid you get that bulkhead connector from? did it come with all the pins?
Very Nice work by the way on both of your trucks!!
pcorriveau951 is offline   Reply With Quote
Old 08-16-2008, 02:54 PM   #221
68 short step
yea, i suspose you could leave them open... and you're right, it probley will never be left outside for any extended period of time....
the connector i ordered though my work, dont remember the name of the place off the top of my head.....but it is a bulkhead connector used on many aircrafts.......the connectors were bought seperate...
and thanks for the complaments
Old 08-17-2008, 07:24 PM   #222
68 short step
a little more progress this weekend....
got the mirror image of the pass side transfered to some metal. then tacked it into place.....my wife helped me a bit on the welding.....smoothed the welds and now i just need to make the other peice(held on by the magnets)....then ill build a stiffener for the firewall to support the weight of the brake set-up....
Old 08-17-2008, 07:57 PM   #223
babyblueoval
babyblueoval's Avatar
68 short step,
Looking good. I wish my wife knew what a welder was.
Question about the tranny. Will they fit any LS series engines?
I've got an LS1 and I'd really like the potential fuel economy of the 6sp and I don't want to do a standard. Any idea what kind of compatibility issues I might have? I currently have a 4L60E.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 08-17-2008, 08:07 PM   #224
68 short step
Originally Posted by babyblueoval View Post
68 short step,
yes they will bolt right up to any gen3/4 engine....as for the wiring and the brains, thats a diffrent story...
Old 08-17-2008, 08:10 PM   #225
babyblueoval
I kinda figured that would be the case. Thanks for the info.
Jim
