Old 07-21-2008, 06:44 PM   #1
1987_3/4ton_chevy
Cowboy Up
350 re-build, going in my 1968 GMC
here is some photos of the re-build 350....
[IMG]
http://i187.photobucket.com/albums/x2/Cowboy_2010/m_97d1bb78bb89d61333599a201ed1cf51.jpg[/IMG]
1971 chevy k10 *Under the Knife*
Chris Cary
1987_3/4ton_chevy is offline   Reply With Quote
Old 07-21-2008, 06:44 PM   #2
1987_3/4ton_chevy
Cowboy Up
Re: 350 re-build, going in my 1968 GMC
Chris Cary
Old 07-21-2008, 06:49 PM   #3
VanceH
Loving the Jimmster
VanceH's Avatar
Very nice, i wish i knew more about engines!!! I would love to do that. Again vere nice pics
vance
VanceH is offline   Reply With Quote
Old 07-21-2008, 06:55 PM   #4
BigBlocksRule
Specs???
BigBlocksRule is offline   Reply With Quote
Old 07-21-2008, 07:10 PM   #5
1987_3/4ton_chevy
Cowboy Up
i don't know much about doing that stuff either, i am having having "berry's Machine" down in Mason City, Iowa do it. Really nice guy and not bad for price. also, he is welling to teach
Chris Cary
Old 07-21-2008, 07:13 PM   #6
1987_3/4ton_chevy
Cowboy Up
Going into a 1968 c2500. its a 350
Chris Cary
Old 07-21-2008, 07:22 PM   #7
Billla
Billla's Avatar
Not to go OT - but I was born in Mason City, and I did my very first engine overhaul ('68 327) with Berry's in 1978 This is the light brown brick building behind what used to be Fairway Foods, right?
Billla is offline   Reply With Quote
Old 07-21-2008, 08:53 PM   #8
big_al_71
big_al_71's Avatar
looking good, I am also curious what combo you are doing (specs)
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 07-21-2008, 11:27 PM   #9
1987_3/4ton_chevy
Cowboy Up
yes that is berrys
Chris Cary
Old 07-22-2008, 09:08 AM   #10
steelhorse
steelhorse's Avatar
What heads are those?Have you run /dynoed the engine yet?
steelhorse is offline   Reply With Quote
Old 07-22-2008, 01:52 PM   #11
1987_3/4ton_chevy
Cowboy Up
The Heads are the orginal ones off the engine. There were no cracks so i am useing the same ones and they are good ones so ya. I have not Dynoed it yet... hopefully soon
Chris Cary
Old 07-30-2008, 01:10 PM   #12
1987_3/4ton_chevy
Cowboy Up
whats the best way to begine when you first start it? like it idle or take it out right away but not harming .. YET?
Chris Cary
Old 07-30-2008, 04:07 PM   #13
steelhorse
steelhorse's Avatar
If you put a new cam in it follow the manufactures recs.Usually run it at 1500 rpm for 15 minutes then shut it down and check everything.I usually change the oil after running it a couple of hours the again at 50 miles then regular schedule,but Im really picky about new motors.
Old 07-30-2008, 10:30 PM   #14
1987_3/4ton_chevy
Cowboy Up
see "Berry's" the guys that are re-building it told me to take it out right away and slow get it up to 5- 60 MPH and back it off to about 30 MPH. Is that better or letting it idle?
Chris Cary
Old 08-02-2008, 11:06 PM   #15
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
Hey guys....to help clear some stuff up for Chris the engine is a 3970010 block, unsure of heads although i would assume stock heads with that block. Block was completely gone through, magnafluxed line bored, honed etc.
Installed stock intake, new bull horn style exhaust manifolds, orig. crank., new pistons and i THINK rods, pistons are stock compression etc. Installed a crane .440/.440 "266" grind profile camshaft. New oil pump, water pump, fuel pump, harmonic balancer, dist, etc. etc. Still has the orig. carb on it but i think he would gain a lot by going to a performance aftermarket carb, BG, Edel., Holley etc. Theres a ton of other small stuff hes done to it that doesnt really effect performance in any manner.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 08-05-2008, 12:26 PM   #16
1987_3/4ton_chevy
Cowboy Up
thanks dude.
I have a question, I bought these house braids... http://www.jegs.com/i/Spectre/865/7496/10002/-1
I am wondering if anyone has these on there truck? I know you gotta put the reg. hose in them but does the hose gotta be a size smaller to put in them or what?
Chris Cary
Old 08-30-2008, 12:07 AM   #17
1987_3/4ton_chevy
Cowboy Up
hey,anyone know anything about these or use them? what u think about using them? good or bad?
Chris Cary
Old 08-30-2008, 01:06 AM   #18
Wreckless_71
Wreckless_71's Avatar
This is straight from the machinist/engine builder that helped my build my engine. Basically do it like it was mentioned before. Fire it up(make sure you have primed the engine before you jump the gun) run it at high idle 1500-2000 RPM for 15-20 minutes then shut it down and check everything out. Once you have done this he said go find a big hill and go up and down it letting the engine compression brake you on the way down. Apparently this helps set the rings. Then break it in like you're gonna drive it. I've done probably 100 rebuilds on my motorcycle and this seems to be the best method, ride it like you stole it. I broke it in using the manufacturers specs once and first time at the track KABLOOYEEE, pop,pop,sputter, S!@#.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
