Old 07-22-2008, 12:35 AM   #1
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Anyone have Longhorn 4x4 frame mod pictures?
I am gearing up to do my 4x swap to my Longhorn and was curious if any of you have any pics of your frame where the shackles are going to end up. Mine has a notch and slit kind of like where an e-brake cable would go in. Is this in the general area, and will that give me problems with my shackle placement? My truck is a 72. thanks for any help/pictures you all can provide.
Old 07-22-2008, 12:43 AM   #2
72-c20
Packrat
72-c20's Avatar
Re: Anyone have Longhorn 4x4 frame mod pictures?
cool. another Iowan close by
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 07-22-2008, 01:53 AM   #3
Dieselwrencher
Yep not far from Des Moines, and I rent part of a shop at 6th and Hartford.
Old 07-22-2008, 10:33 AM   #4
BobS
BobS's Avatar
I don't have pics but will be doing the same thing with a 1-ton frame. The problem area for the rear hangers of the front leaf spring is the area where the emergency brake cable passes through the frame. Some guys heat it up and hammer it flat, some cut it out and weld in a flat piece of steel. I'm leaning towards the cut/weld approach.
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 07-22-2008, 06:57 PM   #5
Dieselwrencher
Thanks Bobs, that is what I am thinking of doing as well. I cruised the site and found a pic of a C30 71ish that was converted ans it looked like he welded a piece over the outside of the frame but I can't tell 100% on that. I will take pics when I do mine.
Old 07-22-2008, 07:59 PM   #6
FormerMember
I did it... pics in my C to K conversion thread.
Edit: I just used longer springs to avoid the ebrake hump.
I have a longer frame that once cut will match up to a LongHorn bed.
FormerMember is offline   Reply With Quote
Old 07-23-2008, 07:30 PM   #7
Dieselwrencher
Thanks for the link! I found the pictures and I will probabaly cut the e brake spots out and install a flat piece and plate the outside portion for support if needed.
