Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-22-2008, 07:48 AM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
Me making a motor hit
Twisted axle shaft
My little garage
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-22-2008, 09:48 AM   #2
djracer
djracer's Avatar
Re: Me making a motor hit
What kind of axle is that?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 07-22-2008, 10:25 AM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
31 spline 9" .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 07-22-2008, 12:02 PM   #4
djracer
djracer's Avatar
Time for those moser 35's. They are some strong suckers. And mine are gun drilled.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-22-2008, 07:17 PM   #5
JayG
Formerly ADHDCARGUY
JayG's Avatar
That's a sweet looking LUV truck! Oh, that also haul a$$!
Jay
67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C.
54CHEVY - BURB, beginning construction(well, i gotta take it apart first!)
36FORD PU - WAITING
38CHEVY - 2DR SD,CHASSIS FINISHED
46CHEVY - BURB - waiting
JayG is offline   Reply With Quote
Old 07-22-2008, 09:44 PM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
I'll bet a dollar to a donut them are Strange axles!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 07-23-2008, 07:13 AM   #7
PA-IndianRider
PA-IndianRider's Avatar
Why so??? All of them look the same to me..... is it because it is so twisted up???
Are STRANGE axles known(or thought to be) weaker than other brands????
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 08-13-2008, 11:26 PM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
Today I ordered New Moser 33 spline Axle and spool kit with bearings and retainers .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-14-2008, 09:19 PM   #9
Marv D
Marv D's Avatar
That ought to be the last axles you ever have to buy. Moser is great stuff.
Indian rider,, sorry I missed your question. Let me put it this way. I twisted a 33 spline Strange SS axle in the 9" in the truck (12 second machine), then snapped a Strange Drag axle in the Nova when it was running 10.3's, replaced it (like a fool) and twisted the other when the Nova dipped into the high 9's. Now that it is into the 9.teens,, it has nothing but a set of MarkWilliams axles. I've pulled them every season and they are as straight as the day they went in there. IMO strange axles are nothing but junk. I do run one of Strange's aluminum Pro-gear centersections in the Nova and it's held up flawlessly. But I'll never risk my life on another Strange axle,, NEVER.
Old 08-14-2008, 09:52 PM   #10
hotrod 80
mini truck racer
hotrod 80's Avatar
I am preparing for the 23rd race . Exhaust is out . Trans swap ( to powerglide ) is about half way done . Working on wiring for transbrake and nitrous . Changing from short tubes to long tube headers , as I found a set of new un used super comps on Craigslist . The old exhaust won't work as im going 3.5" and the fuel tank is in the way . I will not have enough time to to install a fuel cell so i'll have to have an acception in the exhaust . I also bought a new Kirkey and fresh belts , but it might not get installed due to time constraints . I'm hoping freeing up the exhaust and the glide with brake will get it in the .40 - .50 range so i can be competitive . I will be busy this weekend and next week .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-14-2008, 10:04 PM   #11
Rodms
Rodms's Avatar
Agree DJ moser and next Crap on ford,Truck looks good,take a look at some dana junk
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 08-24-2008, 09:49 PM   #12
hotrod 80
mini truck racer
hotrod 80's Avatar
Just thought id throw out an update . Got the rear axle back together and the glide installed . Also put a set of large tube full lenth hooker super comp headers on it . @ 3200 lbs on an 82 jet and a dot drag radial , I put my best ever pass of 10.36 @ 127 . I backed that up with a 6.45 @105 @ the small track that evening . 12" to 18" wheelie every pass and dead hooked . It went 1.50 60' right out of the box . I'll play with the bars and see how much "hit" the radials will take . About 5 pics have surfaced already , if any good ones show up i'll post' em .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 08-24-2008, 10:48 PM   #13
Rodms
Rodms's Avatar
1.50@60 is haulin good job man!!! Wish we could just get healthy right now,been plagued by problems this year
Built chevy tuff!
Old 08-26-2008, 06:36 PM   #14
70rs/ss
70rs/ss's Avatar
Maybe a silly question, but did you put an extension of the header if it open still? Evey thing I have seen says at least an 18" extension from the headers increases hp and tq, just wondering if you did (I am sure you guys all know that, but want to ask, and see if it is true/noticeable at all?) BTW that thing keeps mocking me, I drive by the Luv I talked about last year, free just come get it and I haven't done it as I have nowhere to hide it! Complete running driving truck when parked, pull the 4 out and sell it, then V8, and I'll be getting it (maybe not exactly like yours, but!) Maybe I'll get it and let it sit untill I have the time, back surgery has put the brakes on any wrenching for about 6-8 months, oh well I can still live life through this board and forum
70rs/ss is offline   Reply With Quote
Old 08-26-2008, 11:47 PM   #15
hotrod 80
mini truck racer
hotrod 80's Avatar
I just welded a set of Schofield dirt track mufflers to the collectors for now . They let me run in the jackpot saturday , but it will have to be within 16" of the rear axle before the next official race . Prolly gonna pull this little motor and try and get the big one in it before the next one . Intend to paint it the same color and just not tell anyone its been changed . i'll still be under the CI limit. The fastest pass saturday night was a 6.11 from a metric malibu with a 406 .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-02-2008, 01:40 PM   #16
70rs/ss
70rs/ss's Avatar
396 SBC, I can't wait to see the picts!! I am envious in so many ways!! I have diddle around with so many different projects instead of focusing on one and getting done or at least to a good point. I think of all the $$$ I have spent all over on the various projects and figure I could have finished one or two nice running ones if I had just focues!! The 383 I had built is just one of the attempts at focusing (ADD meds help, I just was diagnosed about 6 months ago!), so being able to concentrate on one thing and see it through is a skill I am honing now. I think this Luv is too cool!! I rolled with a buddy back in the early 90's in a 355 powered Luv and it was the coolest, now your's and I am thinking hard on doing one! Congrats on the time, and can't wait to see picts of the stealth motor swap?!
Old 09-03-2008, 11:28 PM   #17
hotrod 80
mini truck racer
hotrod 80's Avatar
Thanks for the props guys . This is the fastest i've been . The 396 is kinda on hold . I live in the galveston bay area and we have alot of off shore boats down here . My machinist has a shop full of Scarab type boat motors . I walk in and there 2 Bryant billet cranks with the works for 2 509's and 5 BIG small blocks being machined . it's hard for a buisness man to stop and work a day and a half on my junk when he can just keep working on serious profit jobs as there is only so much summer action . He will always have a winter full of race cars and the faster i go with the little motor the more he sales . He has peoplr call him before i do telling him about what i do . The class im runnin will be a 5.80 class eventually .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-04-2008, 12:08 AM   #18
Rodms
Rodms's Avatar
Good deal man,glad its going
Built chevy tuff!
Old 09-05-2008, 01:09 PM   #19
70rs/ss
70rs/ss's Avatar
Too sweet, and I used to live down in Nedeland and was at the beach/Galveston nearly every weekend, those boys play with some big toys and the $$$ they spend is serious. Oil picking back up has I am sure injected some more $$$ into the economy as well!!
Old 09-05-2008, 07:47 PM   #20
nxtruck
nxtruck's Avatar
Man, I do like that little Luv!
5.80s will be tough to run with your cubic inch. Are you guys limited on the jet size in your plate? You're runnin' 6.40s right now with roughly a 200 shot. If you can jet up, there's more to be had, obviously, but I don't remember seeing if you had posted up your class rules. What plate are you running? A 300 shot would pick it up another couple tenths or so, but that 350 is only going to go so fast. Can you guys run a progressive or multi-stage?
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 09-06-2008, 12:53 AM   #21
djracer
djracer's Avatar
he is workin on a larger motor!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-06-2008, 06:14 AM   #22
hotrod 80
mini truck racer
hotrod 80's Avatar
Workin on cubes , like DJ said . I posted a thread about tthe rules awhile back but 82 is the jet limit . My tune up is probably as edgy as it gets . I run a cheater plate . I don't think the bottom end would hold 300 , but im would try it if they would let me . They check the round winners jet after every pass while it is on the scale . Basically stock suspension , drag radial (can only got one size above 275 ) , 3200 for 410 max small block 3500 for 470 max big block , all glass , full interior , state inspection type stuff , exhaust within 12" of rear axle . NO progressive controllers , 76 mm turbo with no intercooler . Basically the ragged edge of streetable http://texastuffstreet.com/EVILSTREET.htm
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 09-06-2008, 11:01 AM   #23
hiway
Mad Scientist
Very cool little truck! Surely there are better plates out there than an old school Cheater?
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 09-06-2008, 11:46 PM   #24
nxtruck
nxtruck's Avatar
Yeah, I did read where you're getting ready to build a 396, but I guess I thought by your post above that the 396 project was on hold and you were going to try and make your little motor competitive.
The 82 jet rule makes it tough to pill it up!! If it were me and I was trying to win in this class( as opposed to just competing ), I would build as close to a 410" motor as I could. With the best heads I could afford. This applies if the rules state 410" max. If it's a pounds-per-cube deal, then I'd be looking at something a little smaller and getting as much weight out of the truck as I could.
I will say that for a 350, you've got it running pretty good!
Chris
Old 09-09-2008, 11:09 AM   #25
hotrod 80
mini truck racer
hotrod 80's Avatar
Im waiting on the machine shop on the other motor . Taht is why im trying to be competitve with the little motor . I wish it where a pounds per cubic inch class id be alot better off , as the truck usually weights in @ just under 2900 # . I have weight bolted in the truck to make 3200 # s . I also think going to a 26" tire would help . I would go with a 400 , but the stuff i have and my budget will only allow for the 396 . It went 6.45 the other night , if i can get it into the 6.30's i can run with them . the fastest pass is like 6.11 right now . Looks like someone has called the king out for his spot . I'll probably get in on this if this hurricanne doesn't blow us away . For a call out everyone put's up $100 , qualifies and gets stacked on a ladder , the winner gets to run the king heads up for the money and the title . one shot one kill . At the event the king just shows up and makes one hit and runs the winner of the class for the kingdom .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
