Old 07-21-2008, 08:43 PM   #1
salrod00
salrod00's Avatar
89 tbi fuel pump
I have a 89 suburban tbi motor and tranny put in my 85 c-10. Can I use my stock saddle tank off the truck and shorten the electric fuel pump out of the suburban to make it fit in the tank. what problems would I have or is it even possible. Whats the best route or advice for me to make this motor run.. thanks ahead of time ..
salrod00 is offline   Reply With Quote
Old 07-21-2008, 08:45 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 89 tbi fuel pump
Ditch the saddle tank. Install the rear Suburban tank.
http://www.captkaoscustoms.com/blazertank.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 07-21-2008, 08:47 PM   #3
joe231
joe231's Avatar
how about a frame mounted electric pump, simple and quick install
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-21-2008, 10:10 PM   #4
salrod00
salrod00's Avatar
what brand and how would a side frame electric pump be installed. i never installed one before.. i got the suburban tank but i made a hole in it. so that eliminates that. any pics or info would be great..
Old 07-22-2008, 09:09 AM   #5
slug
slug's Avatar
if you are going to use a remote mounted electric fuel pump, your going to need to find out the opperating pressure of the stock suburban tbi pump and match the new pump to that. you will also need a fuel return line and possibly a bypass type fuel regulator.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 07-22-2008, 09:56 AM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Buy a sending unit for a 87-95 pickup and use the parts off the Burb and drop it in your current tank.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-22-2008, 06:01 PM   #7
salrod00
salrod00's Avatar
my current tank is the one off the c10 truck. i beleived that are called saddle tanks. the suburban tank has a mase or tunnels inside it while the one off the truck is just four walls.
Old 07-22-2008, 07:57 PM   #8
gchemist
gchemist's Avatar
Holley makes pumps for TBI fuel pressure. TBIs require 15 PSI.
In tank fuel pumps are cooled by the fuel. Frame rail pumps are not cooled and are at the mercy of heat.
Old 07-22-2008, 09:57 PM   #9
salrod00
salrod00's Avatar
i went ahead and bought a stock gas tank of another 89 suburban. i drop the electric pump (stock sending unit) in the tank and now the truck wont stay on. it turns and tries to crank but it wont stay on. i ran the sending unit direct to a switch. yall think that i got a wire issue...
