03-25-2002, 12:05 AM | #1 |
Ignition switch removal
My new blue 72 needs new ignition switch and bezel. Looks like the last guy tried to pry out with a screw driver. Please refresh me on proper procedure. I know that pin hole is there for a reason
------------------[list] [*] 1972 Cheyenne Super 20 LWB[*] 1972 Cheyenne Super 10 LWB[*] 1972 Chevy Custom 20[*] 1971 Cheyenne 10 LWB[*] 1968 1/2 ton lwb project[*] 2 1980 camaros 1 done 1 getting started[*] 3 1949 ford 8n tractors[*] 1987 camaro[*] 1996 Chevy Tahoe /[list]
03-25-2002, 12:10 AM | #2 |
paperclip and counterclockwise usually works
03-25-2002, 12:20 AM | #3 |
Ok, you probably know some of this already, but I will tell you what I know about how to do it. 1. stick a paper cilp in the hole, put the key in and turn it to the Acc. position, push the paper clip in and the switch should come out. 2. unplug the wires from the switch (this part looks simple, but the plug is really hard to get out. 3. unscrew the bezel from the metal piece that the ignition switch fits into. I hope that helps
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
