Old 02-10-2003, 04:54 AM   #1
87gmc
I Got My Engine!!!!!
87gmc's Avatar
Stupid P.o.s.!!!!!!!
Well my truck decided to go poot. It still runs but when i start it up there a clicking/ticking/knocking noise the gets faster as the rpms increase. It sounds like it coming from the back of the engine but i havent messed with it yet, (started tonight) will pull it in the shop and look at it tomorrow, but what should i be looking for?
Any help would be great.
Cameron
F.O.R.D.
"F*cked Over Rebuilt Dodge"
-+-+-+-+Cameron+-+-+-+-
1987 GMC HIGH SIERRA LWB 1500
32X11.50
383 TBI/Vortec Heads/Intake
MSD Ignition
Dual Exhaust
Custom Pinstriping
Sweet interior & stereo
http://www.cgalvin29.freehomepage.com
87gmc is offline   Reply With Quote
Old 02-10-2003, 05:09 AM   #2
Prerunner1982
Prerunner1982's Avatar
blew a rod? my 305 had a severe knocking coming from the rear bottom of the engine.. didnt bother taking it apart to figure it out...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-10-2003, 05:21 AM   #3
87gmc
87gmc's Avatar
no i dont think so. say maybe bent but it runs really fine no power loss at all but just the clicking but i dont wanna run it till i get it fixed.
F.O.R.D.
32X11.50
MSD Ignition
Dual Exhaust
Custom Pinstriping
Old 02-10-2003, 05:44 AM   #4
Prerunner1982
clicking? header collector gasket?
Jon
Oklahoma Roll Call
Old 02-10-2003, 05:49 AM   #5
87gmc
87gmc's Avatar
maybe, ill have to look into that
F.O.R.D.
32X11.50
MSD Ignition
Dual Exhaust
Custom Pinstriping
Old 02-10-2003, 05:52 AM   #6
Prerunner1982
i need to do mine as well.. i can hear it clicking... annoying as hell..
Jon
Oklahoma Roll Call
Old 02-10-2003, 07:10 AM   #7
87gmc
87gmc's Avatar
Could it be a bad u-joint?
F.O.R.D.
32X11.50
MSD Ignition
Dual Exhaust
Custom Pinstriping
Old 02-10-2003, 07:15 AM   #8
Prerunner1982
does it make the sound only when driving? or just when it is running?
Jon
Oklahoma Roll Call
Old 02-10-2003, 07:16 AM   #9
87gmc
87gmc's Avatar
Both, its a slower clicking at idle and then when i accerlate in increases with the rpms/speed
F.O.R.D.
32X11.50
MSD Ignition
Dual Exhaust
Custom Pinstriping
Old 02-10-2003, 07:37 AM   #10
Prerunner1982
u-joint doesnt spin at idle. more than likely not it...
Jon
Oklahoma Roll Call
Old 02-10-2003, 07:40 AM   #11
87gmc
87gmc's Avatar
hmmm
F.O.R.D.
32X11.50
MSD Ignition
Dual Exhaust
Custom Pinstriping
Old 02-10-2003, 09:34 AM   #12
swervin ervin
You get what you pay for
swervin ervin's Avatar
It's definetely something which is engine rpm related, do drivetrain is not it because it's not moving. You will need to see where it's coming from, bottom or top? If top, it's probably a lifter or cam lobe going flat. A rod won't click. A rod makes a pecking sound sort of like pecking on the side of the block with something. Pecking sounds like lifter, rocker arm, pushrod, or cam to me.
If I were guessing, and this is all it is, a guess, I would guess at lifter or cam lobe. Probably cam lobe going flat. But don't panic until you figure it out.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-10-2003, 09:37 PM   #13
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
If you don't turn up anything else and it's an Automatic check for a crack in your flex plate.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 02-10-2003, 11:31 PM   #14
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
Can you tell if it happens every revolution or once every OTHER revolution?
once per rev is crank/rods/etc
once every other will be valvetrain..
8 out of 10 times it will be a flat lobe on the cam, a loose or worn rocker arm, or a cam lobe that went flat... get a stethoscope (a couple feet of heater hose), and remove the valve covers and start the motor and have a look
mike
mike reeh is offline   Reply With Quote
