Old 07-28-2008, 09:38 PM   #1
Brad2thabone
Brad2thabone's Avatar
help with axle plz help
today i removed the axle out from my truck to remove some old brackets on it. Im goin to be installing a parallel link soon, im worried that when i put it the axle back in place and weld the links that it will be crooked, any ideas to keep it straight?
Brad2thabone is offline   Reply With Quote
Old 07-28-2008, 10:01 PM   #2
joe231
joe231's Avatar
Re: help with axle plz help
measure, measure, measure, measure, and measure
when you think you are done. measure some more
find places to reference on the frame that are symmetrical and measure on the diagonal, side to side, and front to back to keep everything square
wouldn't hurt to keep a note book to jot down measurements
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-29-2008, 04:53 PM   #3
Brad2thabone
Joe, thanks alot man...i really appreciate the help.
Old 07-29-2008, 09:38 PM   #4
joe231
joe231's Avatar
no problem
CHEVY ONLY
Old 07-29-2008, 10:41 PM   #5
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
You cuold also just tack weld a couple pieces of 2x2 square tube to the frame and axle at ride height to keep it positioned, make sure your pinion angle is correct, and weld the 4link in place. When done remove the square tubes.
79 Burb,350,tremic 5 spd, 4 wheel disc, daily driver
74 swb,350,350,driver & future project
"There's no such thing as a finished project"
GMBowtie79 is offline   Reply With Quote
Old 07-29-2008, 11:50 PM   #6
joe231
joe231's Avatar
good thinking!!!
CHEVY ONLY
Old 07-30-2008, 12:09 AM   #7
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
be sure to have the pinion angle set at your desired ride height. one mistake I made early on in my shop days was I did just what you're describing but I tacked the axle to the frame at the stock height. my actual end result height was ~8" lower and the pinion angle was off. there wasn't enough adjustment for me to get a satisfactory result.
anyway tack your axle in where you plan to be at ride height. and set your brackets so your bars are parallel to the ground. you can use a magnetic dial angle finder to get your pinion set and then tack there before you double check every measurement.
a lot of guys will hang the axle from some old U-bolts tacked to the frame that way the axle can be slid side to side or rotated to the correct pinion.
josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 07-30-2008, 12:38 AM   #8
joe231
joe231's Avatar
hey RunninLo...sorry to 'jack this thread....you running or have you ran a york engine driven compressor???? if so, got any pix??.......[/hijack]
CHEVY ONLY
Old 07-30-2008, 10:28 AM   #9
RunninLo
RunninLo's Avatar
I have one but it isn't in yet. I'll be making my own brakets I think. Good york resource here:
http://www.kilbyenterprises.com/compressors.htm
and now back to our regularly sheduled thread,
Josh
88 4x4 crew DD
Old 07-30-2008, 10:38 AM   #10
joe231
joe231's Avatar
cool, thanks
I'm planning on making my own brackets to mate it to my 283, just looking for ideas
CHEVY ONLY
Old 08-03-2008, 09:49 PM   #11
Brad2thabone
Thx guys, im almost ready to weld the paralell link. I just need to make a million measurements. Ill post some pics soon.
