#26 |
Re: 1950 project
got the hydroboost fitted tonight, it is from a 92 GMC safari van $12 at the local u pull it. TCI pedal assy and a corvette master cyl.
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
#27 |
Tripple Five Fanatic
Re: 1950 project
I like the Hydroboost setup. I picked one up from the yard to put on my 55.2. I already have the regular booster in that location but will try to adapt the bracket, and master cyclinder to the booster.
Did you modify the bracket to make the booster fit? How about the lines? I would suggest getting the banjo connectors instead of the 45* connectors. That's what I'm going to do on mine. |
#28 |
Certified Car Nut
Re: 1950 project
Nice build you have going. By the way what headers did you go with.
#29 |
Re: 1950 project
yes please let us know your header choice it's been quite an issue for me as well. i may have to go with stockers myself..
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
#30 | |
Re: 1950 project
http://store.summitracing.com/partde...5&autoview=sku I really wanted long tubes but do not have enough clearance for the steering hook up to the rack, with theese I sould have no problem. they clear the frame rails by 1 inch at the closest point. the stock manifolds did not even come close to fitting. I would have had to notch the frame rails.
#31 |
Re: 1950 project
Nice build. It will be a sweet driver.
#32 | |
Certified Car Nut
Re: 1950 project
#33 |
Re: 1950 project
It's alive!!! I started the motor tonight after sitting for 2 years. it only had 50 miles on it but you still never know buying used parts. the engine barely made one revolution before it kicked right of and purred like kitten. you gotta love fuel injection.
#34 |
THE VILLIAGE IDIOT
Re: 1950 project
nice project.. col that the motor started right up..
honestly honey,,i have no idea how that truck got here. ![]() |
#35 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: 1950 project
Congrats on the mill fireing right up..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#36 |
![]() Join Date: Jun 2002
Re: 1950 project
congrats on firing it up, that sure makes ya step up the pace don't it!! your gonna love the way she runs down the road
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 Last edited by Kid; 08-05-2008 at 10:45 PM. |
#37 |
THE VILLIAGE IDIOT
Re: 1950 project
not to sound stupid, well maybe dumb question...but what does AD stand for.. seen it refered to on a couple of this style of truck...for the life of me if i knew what it meant ive forgotton..lol
billy
#38 |
Re: 1950 project
Advance Design
#39 |
Re: 1950 project
yes it does, now to tackle the cab repair
1971 Corvette convertible 454@ 525 hp ![]() 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck Last edited by 50adrod; 08-06-2008 at 10:30 PM. |
#40 |
THE VILLIAGE IDIOT
Re: 1950 project
ok thank you ....
#41 |
Re: 1950 project
Back in the day this truck was quite a departure from the previous trucks if you've ever been in a 46 chevy you'll notice you can roll down the passenger window without much effort.
in other news is there any way you could get a shot of your headers i'm still undecided i would prefer the tube header... thanks in ADVANCE GT
#42 | |
Re: 1950 project
#43 |
progress and confusion
made progress this weekend but I am also scratching my head. I welded in the firewall and floors and also hung the doors for the first time since I had the truck. I bought it in pieces. I mounted the firewall with screws and put the cab back on the truck so I could locate my motor and weld in the mounts.
and now after it is all welded in the firewall hits the motor. ![]() the motor mocked up before the firewall was welded ![]() ![]() the firewall welded in ![]() floors welded in ![]() motor out ![]() at least it is looking like a cab again ![]()
#44 |
Certified Car Nut
Re: 1950 project
Thats just great. Congrats on reaching that milestone.
#45 |
Re: 1950 project
do you have any clearence on your radiatior in the front of the engine. your firewall should clear. my stock firewall works for a 350 with no modifications. wonder of you need to modify your engine mounts?
GT
#46 |
Re: 1950 project
I should have room to move it forward considering it fits with a stock firewall. the thing that bugs me is I purposley put the cab back on the frame to locate the eng and trans. and it cleared the firewall with 3/4 inch to spare. the first pics showing the clearance was with the mounts welded in place. my first thought was I possibly had the front cab mounts off a little but they line up perfectly and the rear cab mounts also line up perfectly. I will try and mount the engine back in tonight and see what happens.
#47 |
Re: 1950 project
with my ls1/street and perf. air filter/ and shorty but fatty rad. and fan shroud I had to build a custom core support to give me enough clearance in the front to clear basically the stock firewall in the back of the engine. my custom rad. support drops the rad about 4-5 inches from stock and moves it forward by about 3.
since your firewall is recessed quite a bit I'd say your fine. |
#48 | |
Re: 1950 project
4 inches from the radiator (I am running an electric fan) ![]() and a little farther from the firewall than before ![]() ![]() cajun, my disadvantage is I bought this truck apart and do not know how much room there is for the rad to move forward and i also need a condensor upfront. got any pics of yours installed.
#49 |
Re: 1950 project
You probably already thought of this but I would put on the accessorie pulley, fan, etc. to make sure you are not causing any other problems with radiator interference. I know on my 4wd conversion I am really having to think ahead to keep from doing stuff twice. Looking good so far.
#50 | |
Re: 1950 project
