Old 07-29-2008, 10:11 AM   #1
merlin65
merlin65's Avatar
ram horn help!!!
I got this problem. I am running ram horns on my 283 and cannot find the right altenator bracket. My driver side manifold has the cast in bracket tab but I cannot find a bracket to work on it. I have been pulling out my hair for months. I made one thaty kind of works but I want the right one so I dont have to worry about throwing a belt. I bought one of the low mount brackets for the bottom of the engine, but the altenator does not really line up with the crank pulley. Any ideas or pics? What are you guys with ram horns running for bracketry????
merlin65 is offline   Reply With Quote
Old 07-29-2008, 10:24 AM   #2
LILRED66
LILRED66's Avatar
Re: ram horn help!!!
Go to your favorite local auto parts store (FLAPS) and look in their specialty section. Mr. Gasket makes a bracket for the top of the alternator to the water pump and a bottom bracket that attaches to the front of the factory ram horn exhaust manifold. I have this set up on a few of my 4-5-6 Chevy trucks with 283/327 V8 engines and factory ram horn exhaust manifolds and they work great.
I hope this information is helpful and good luck with your project.
LILRED66 is offline   Reply With Quote
Old 07-29-2008, 10:24 AM   #3
ValveTubeHead
ValveTubeHead's Avatar
For ref: Here's what the oem lower bracket looks like...not sure if p/s equipt bracketry looks any different. You may note the spacer bushing welded to the business end.
top
Matt
'65 LWB Fleetside
'63 SWB Fleetside
ValveTubeHead is offline   Reply With Quote
Old 07-30-2008, 12:12 AM   #4
joe231
joe231's Avatar
i'm gonna assume (i know, i know) you have a short water pump
parts A and C i believe is what fits mine(283 swp),
Name:  mr gasket.jpg
mine is different than valvetubehead's
here is the LINKY
i can get pics of mine if you need them
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-30-2008, 12:16 AM   #5
LILRED66
LILRED66's Avatar
Nice job with the photo and explanation Joe! Thanks. Piece D is for headers.
Old 07-30-2008, 12:29 AM   #6
joe231
joe231's Avatar
thanks Tony!
what do you know about the style valvetubehead posted, different years???
CHEVY ONLY
Old 07-30-2008, 01:54 AM   #7
ValveTubeHead
Originally Posted by joe231 View Post
thanks Tony!
my brackets were oem for '65 on 283; no p/s or ac
Ive since swapped the original 283 for a crate 290hp 350; and opted for a low mount bracket (Mr. Gasket p/n 5179). The upper mount header combo business wasn't doing the trick in my case. Low mount was a perfect match for me.
Matt
'65 LWB Fleetside
'63 SWB Fleetside
Old 07-30-2008, 08:50 AM   #8
joe231
joe231's Avatar
thanks for the info valvetubehead, i guess you aren't planning on running power steering, huh?
here is a LINKY to a thread with pics of my set up
CHEVY ONLY
Old 07-30-2008, 09:31 AM   #9
ValveTubeHead
nope
Im also a three on the tree hugger and manual drum braker
Matt
'65 LWB Fleetside
'63 SWB Fleetside
Old 07-30-2008, 10:35 AM   #10
LILRED66
LILRED66's Avatar
thanks Tony!
I came across the Mr. Gasket brackets as a result of not having the factory correct alternator brackets. I have since acquired a number of factory set-ups like valvetubehead posted, so I prefer the stock appearance and fitment. For me, it is hard to beat the factory set-up when going "stocker".
Old 07-30-2008, 11:09 AM   #11
joe231
joe231's Avatar
my stock bracket looks like the mr gasket, on the manifold, the bolt holes are in a different location than the pic above, they are on the side of the manifold, not the front. I was curious what the different applications are between his style and mine
CHEVY ONLY
Old 07-30-2008, 11:29 AM   #12
merlin65
merlin65's Avatar
Well I feel like an idiot. I fixed my own problem. I was just thinking way to much. Turns out the altenator will just bolt right the hell up to the ram horn front tabs. I thought the two holes on the front of the manifold were for some kind of special long forgotten bracket. But I bolted it to the upper most outboard hole and attached my chrome arm over from the block and was done. Way to dang simple. thanks for the many responses. I will try to post some pictures of what I am talking about......
Old 07-30-2008, 11:36 AM   #13
joe231
joe231's Avatar
Originally Posted by ValveTubeHead View Post
nope
how does it stop that crate 350? you got a bit more GO! than WHOA!?
CHEVY ONLY
Old 07-30-2008, 11:44 AM   #14
ValveTubeHead
Around here it also takes a keen eye, rapid stereotyping and ample planning to make some stops.
We have a v. large population of underqualified motorists inhabiting our thoroughfares.
Matt
'65 LWB Fleetside
'63 SWB Fleetside
Old 07-30-2008, 12:01 PM   #15
joe231
joe231's Avatar
yeah I bet
CHEVY ONLY
Old 07-30-2008, 12:50 PM   #16
MacAttack
283 Drama Queen
MacAttack's Avatar
Matt - THAT IS OUTSTANDING! Ordering it along with some other stuff from Summit this morning! The C10 won't have any power gear either, so this is a natural.
Thanks,
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 07-30-2008, 12:59 PM   #17
jchav62
1962 C-10
jchav62's Avatar
Thanks,
Mac.
That is a very clean looking set up! If we weren't running P/S in our trucks I would definitely use it.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 07-30-2008, 04:05 PM   #18
ValveTubeHead
That was my first impression...very clean. Also, tall valvecover friendly...although I like the shorts.
Thanks,
Mac.
FYI: Belt is 43.5" =1105mm
eg.Goodyear Gatorback 11AV1105
Matt
'65 LWB Fleetside
'63 SWB Fleetside
Old 07-30-2008, 05:50 PM   #19
MacAttack
283 Drama Queen
MacAttack's Avatar
Dog!!! Thank You!
Mac.
