Old 07-30-2008, 08:11 PM   #1
avysittinon22s
avysittinon22s's Avatar
driveshaft clearence on bagged trucks?
I have my rear bagged with no c-notch, my driveshaft has 1 1/4" clearence when aired out to trailing arm cross member. I would like to get at least 2" more drop. anyone got suggestions?
avysittinon22s is offline   Reply With Quote
Old 07-30-2008, 08:54 PM   #2
shortbed70
shortbed70's Avatar
Re: driveshaft clearence on bagged trucks?
Take your trailing arm crossmember out and cut the bottom of the loop off then weld a similar loop on the top and plate the bottom so its not open then cut off the stock top of the loop. You might have to clearence the back of the cab.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-31-2008, 08:43 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
You shouldn't have any problems with driveshaft clearance with a bolt-in c-notch ala CPP. The shaft will not move that much at the crossmember since it is so close to the tailshaft.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-31-2008, 04:26 PM   #4
avysittinon22s
yeah i feel dumb lol I got to thinking this morning, the rearend is gonna travel farther than the 1 1/4" clearence. Well I took driveshaft loose and raised it up to see how much farther. I measured 4" from center of shaft to center of yoke and shaft hit cab before crossmember. Im planning on getting c-notch in this weekend I hope. notching 3"
Old 07-31-2008, 04:50 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Be aware, with a 3" notch, your axle will be hitting the bed floor. You will have to trim the upper shock crossmember as well...
-Chris
Old 07-31-2008, 07:05 PM   #6
avysittinon22s
How much can I notch till axle hits bottom of bed? Is it possible for rear to set as low as front without cutting bed floor? My front is upper plates and bottoms cups 1.5" .
Old 07-31-2008, 07:49 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
About 2 1/2". The bolt-in CPP notch with the bumpstops installed will not hit.
-Chris
