Old 07-30-2008, 09:28 PM   #1
Turtle
metal for patch panel
i need to make a patch for my 62 surburan. does this sound correct? 18 gauge cold rolled steel.not sure what cold rolled means? thanks
Turtle is offline   Reply With Quote
Old 07-30-2008, 09:43 PM   #2
joe231
joe231's Avatar
Re: metal for patch panel
yes i believe that is what you want....correct me if I'm wrong guys, but i think cold rolled is referring to the process they use to work the metal into the proper gauge.....they roll it flat not using any heat, it makes the final product more resilient.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-31-2008, 12:33 AM   #3
Captainfab
60-66 Nut
Yep that's pretty much it.....cold rolled steel doesn't have any mill scale on it. Depending where you are making a patch the 18 ga. may be a little thicker than the original metal. In which case 20 ga would be closer to the original thickness, although it probably won't make that much of a difference. I'd definitely use 18 ga for floors, cab supports, etc.
Old 07-31-2008, 01:27 AM   #4
original_balzer
original_balzer's Avatar
I like to cut up old ford hoods doors bedsides and roofs to make patch pannels. That is if you can find ford parts that arnt rusted.
OK it was realy only one time.
I literaly cut up a 77 ford pickup to patch the floor in a 72 blazer I had years ago. It was great therapy, and metal is metal right?
-61 c10 short step
-67 c10 short step
-71 k10 long fleet
-77 k20 long fleet (gettin all the goodies from frankentruck)
-79 c30/k30 3+3 frankentruck (cab and frame for sale)
-99 GMC yukon daily driver
original_balzer is offline   Reply With Quote
Old 07-31-2008, 05:49 AM   #5
Frizzle Fry
Frizzle Fry's Avatar
best use of a ford yet
Frizzle Fry is offline   Reply With Quote
Old 07-31-2008, 01:53 PM   #6
rickf
rickf's Avatar
Swedish steel seems pretty good, I've had good success using Volvo doors and station wagon roofs.
rickf is offline   Reply With Quote
Old 07-31-2008, 11:23 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Joe & Captainfab are right on the cold-rolled process. Also, cold-rolled is a mild temper and doesn't have a lot of carbon in it. Makes it easy to form, cut and weld.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 08-01-2008, 01:24 AM   #8
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Built ford tough with chevy stuff, or vice vesa
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 08-01-2008, 10:13 AM   #9
LILRED66
LILRED66's Avatar
Most big box home centers have a section with various sizes of sheetmetal in a variety of gauge thicknesses. I have found this material optimal for patch panels.
LILRED66 is offline   Reply With Quote
Old 08-01-2008, 11:47 PM   #10
soba_03
soba_03's Avatar
I thought that the point of replacing rusted metal part was to keep them from rusting any more...
Your putting FORD metal in there isn't that self defeating?
soba_03 is offline   Reply With Quote
