#176 |
ROCKWELL 5 TON CLUB !!
![]() Join Date: Oct 2006
Re: My Build Begins!
i am working on getting pics up.
got all sheetmetal on except hood for now. all lights are wired up and ready. dash is 75% wired up and ready. engine bay harness is done,send my 5.3 harness to speartech to have connectors and wiring added for cable throttle body,also adding a check engine light and aldl connector,will also be reprogramming the pcm. got the frt and rear seats sittin in it. took a set of shorty headers and cut them apart to make a set of over the frame headers for my 5.3 got new water pump,p/s pump and alt ionstalled. got cable actuated throttle body mounted,new intake gaskets.working on rounding up parts for throttle lnkage. made new upper and lower mounts on the core support to hang my new radiator,its out of a 2007 police interceptor tahoe.will allow me to use all stock upper and lower rad hoses from any 00-08 truck. got latches,locks and handles in both doors,no glass yet,thats gonna have to wait. got both frt inner fenders trimmed to clear my headers and mounted. got the brackets made and welded for my hyd steering cyl.pretty basic. got the brake booster and master cyl blasted,painted and installed. got my wheel centers blasted and painted. ive been busy,tryin to get this thing ready to go. like i said ,im trying to get pics up....
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!" MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=221935 1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS HINT:NEW NAME "K5ontheROCKS!" |
#177 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Cant wait to see some pics of this thing...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#183 |
I'm a poor spectator
Looks good, I want to see this beast when it's done.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! Last edited by Jtrux; 08-01-2008 at 11:12 PM. |
#184 |
![]() Join Date: Apr 2000
is that cool or what...
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
#185 |
big thanks to "J" for the help with pics
thanks for the complements. with work and family this has been a slow moving project, i am so ready to have this thing outside and moving on its own!
#186 |
Nice job man...going to be very cool!
Doing something similar to a 74 crew cab. Lots and lots of time needed! |
#187 |
small update:
due to an unforseen family death and newly arising medical issues havent been able to work on the truck for last 3 weeks.granted the k5 is non-existant compared to family,and we are all pulling to gether and making it thru these tough times.but my k5 is a great source of "stress relief" as im sure most of you feel the same. lots of parts have been accumulating and hope to get some work done onthe holiday weekend. -engine harness is done,had reworked to eliminate some unneded things,add some things,misc.,just need to finish install. -got all the hydro clutch parts to install. -got all my fluids for drivetrain to go in. -got all my coolant hoses. -need to finish hydro steering mounts and such. -got all the parts to finish my fuel system. BUT, there is probably no way its gonna make it to the sept indy 4x4 jambo i had been so trying to make. ill get some pics up in a week or so for an update. thanks andy
#188 |
Can't wait to retire!!
Hang in there Andy, our thoughts and prayers are with you and your family.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#189 |
Hey thanks man.
just one of our "bumps" in life. we'll be back on the k5 soon .............it is getting sooooooooooooooo close to running...
#190 |
Our prayers are with you and your family in these tough times...be strong
#191 |
Its lookin' like a Blazer!
Sorry for your loss man, if theres anything ya need just holler or send me a pm. We'll be prayin' for you and your family.
#192 |
Tallhoe, man were are you. www.trucksgonewild.com is having a taped bog at puddin creek (perry, florida march 13,14,15) i am tring to get mine there. How much longer for you.
#193 |
I want to see the pics on page 6 but with the body on...
#194 |
I have seen some of your pictures on chucks forum. So did you trade out your wheels and tires or not?
#195 |
ok guys,im back got a little update and some pics:
plans have changed. after the engine blew,i began building a 500hp 6.0l.its still going well,almost done actually. but i pulled out my 2.5 ton axles and traded axles/wheels and tires for................................ a set of 7ton rockwells and 4 67/35/25's !!!!!!!!!! yes thats correct 67"ers. heres some pics:
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!" MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=221935 1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS HINT:NEW NAME "K5ontheROCKS!" Last edited by tallhoedude; 02-10-2009 at 09:23 AM. |
#196 |
more pics:
#197 |
pics:
#198 |
ive let all the air out of the tires,they stand about 14" taller w/aired up!!!
some body update pics:
#199 |
just a few more pics;
#200 |
wow, so this is now a monster truck build?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
