Old 08-02-2008, 01:00 PM   #1
1Low53Burb
1Low53Burb's Avatar
Let's see your throttle cable on your AD truck
With a 350.
1Low53Burb is offline   Reply With Quote
Old 08-02-2008, 03:24 PM   #2
1Low53Burb
1Low53Burb's Avatar
Re: Let's see your throttle cable on your AD truck
This is a build picture from under my hood, but I'm needing to know how ya'll have your throttle cable ran to your carb from out of your firewall.
Old 08-02-2008, 06:33 PM   #3
solidaxel
solidaxel's Avatar
I am watching this thread!!
I am looking for a late 50's early 6o Corvette linkage that bolted to the bellhousing, no luck so far!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-02-2008, 07:04 PM   #4
1Low53Burb
1Low53Burb's Avatar
Well, mine had a Lokar but it was cut too short and came apart after driving it for a little while. I just really need to run a longer one with a loop in it.
Old 08-02-2008, 08:49 PM   #5
smittys50
smittys50's Avatar
hope this pic helps.
smittys50 is offline   Reply With Quote
Old 08-03-2008, 10:44 AM   #6
solidaxel
solidaxel's Avatar
I like Lokar products, but isn't there something from the bone yard that can be adapted ?
LS 3 4L70E
Old 08-03-2008, 01:50 PM   #7
1Low53Burb
1Low53Burb's Avatar
My throttle cable comes out of the fire wall too far away from my carb and has it at an awkward angle.
Old 08-05-2008, 12:02 PM   #8
solidaxel
solidaxel's Avatar
Question,
I see that you have your shift arm from the steering column going under the brake arm (shortned), how has this affected the geometry of the indicator on the column? I am having a interference problem also
LS 3 4L70E
Old 08-06-2008, 01:12 PM   #9
smittys50
smittys50's Avatar
Originally Posted by solidaxel View Post
Question,
it was fine with the 350 turbo now with 700r4 it is off and it wont shift to first gear. there is a cable shifter they say works good but i havent seen it. if you find something to work good let me know ( column shift) thanks
Old 08-06-2008, 01:19 PM   #10
jkaylor68gmc
jkaylor68gmc's Avatar
yep, call Lokar
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 08-09-2008, 04:28 PM   #11
weldvair@embarqmail.
I bought a Lokar cable shifter.....it did not work as well as other products I've bought from them. It shifted very hard.
Don
weldvair@embarqmail. is offline   Reply With Quote
Old 08-10-2008, 09:48 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have the lokar eliminator pedal set-up the comes out through the bottom of the floor and then runs up to the firewall.. Ya may want to take a look at those.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-11-2008, 10:21 PM   #13
Augy's '53
Augy's '53's Avatar
I've used the same setup as smittys50. Mine is even shorter, seems to work O.K.. Had to tweek it some to get it to come to idle smoothly, but I think I'll be happy.
Augy's '53 is offline   Reply With Quote
